Old 11-22-2005, 11:33 PM
Rez Rez is offline
Send a message via ICQ to Rez Send a message via AIM to Rez
Drag strip project
Hey guys, I'm working on a project to build a drag strip. It's just in the planning stages so far and will remain as such untill I can save up the money for the hardware.
I needed a drag strip with a tree and beams for finish and foul. I was unable to find an existing product that either had the features I wanted or was within a reasonable price range. So I started designing my own.
The plans call for a basic stamp 2px microcontroller, so I decided to elaborate on the features in order to better make use of the processor. I added in the ability to dial in a handicap for either lane, an LCD panel to deplay average speed, elapsed time, reaction time, total time for each lane, and stage and prestage lights and beams.
I would like to know if people would be interested in using such a system. If so, what additional features would you like to see in the system? Are there any features that should be cut out?
The schematic is very alpha. I need to do some math still to make sure all the tidbits are correct, but I'm pretty sure it's all kosher. I could do away with the seven segment displays and pipe the handicap to the LCD instead. Can't think of anything to do with the additional LEDs the driver IC has open though. Any ideas? The processor has one more IO pin free. With one more IO I could add an RFID reader to the staging area.
After I get the hardware, I can start writing the program.
Rez
a7i20ci7y
Seven Cities RC
Old 11-22-2005, 11:37 PM
Rez Rez is offline
I should mention that I am not an electrical engineer, and I have never built anything like this before
Rez
a7i20ci7y
Seven Cities RC
Old 11-23-2005, 12:31 AM
HammerZ's Avatar
HammerZ HammerZ is offline
Thrasher
Killer idea, I would love to see it made into a kit. That is a lot of connections going everywhere.
Old 11-23-2005, 10:44 AM
KingFuzz's Avatar
KingFuzz KingFuzz is offline
No title
Check out this thread. It has an idea for a timer that I found on another forum. Good luck with this project though.
Drag Strip Thread
Old 12-06-2005, 01:16 PM
Tbird Man Tbird Man is offline
Another feture that would be nice would be scale 60ft times. though that would require another beam. also trap speed would be nice and again, another beam there.
Nissan Skyline GTR v-spec
AWD
suspension upgrade (soft rear med front)
180 size motor, custom made heatsink
GPM alu front knuckles, shocks and center bering holders.
more to come...
Old 12-07-2005, 07:26 AM
Rez Rez is offline
Scale times is just a matter of math. If I have the actual numbers, I can just massage them to scale numbers.
Traps would require beams. One per lane per trap. Technically I could just add more beams to the foul/finish circuit and use logic to figgure out which one is being broken, thus requiring no additional IO pins. Unless a car goes airborn and jumps over a beam, or reverses, it has to pass them in order...
Rez
a7i20ci7y
Seven Cities RC
Old 01-27-2006, 04:12 PM
Roketmini's Avatar
Roketmini Roketmini is offline
XMod Guru and Ninja
Hmmm...that'd be cool, especially if I ever finish my tube-frame xmod rail. I sketched out a plan to put a 6 cell xmod electronics package into a custom brass tube frame. I'll probably use medium lego slicks, and the electronics will be donated by a friend and his wrecked NSX.
I own No-Coast Customs
Instead of reading this, go paint your car.
Xmods: Green Skyline/Black,Gold 350z/Red RSX/Navy/Silver Supra/Messed up Camaro/Silver Mustang Cobra/Copper F-150/Red,Yeellow, Copper Evo VIII
Mini-Z: White Toyota Harrier Overland
all out Drag project mshkttck ZipZaps Gallery 10 12-24-2004 07:59 PM
Drag strip!!!!!!!!!!!!!!! neutrax Tracks 0 02-27-2003 06:48 PM
perfect drag strip zombiebaby Bit Char-G / MicroSizers 3 12-20-2002 02:16 AM
Drag Strip ihavebadgas Bit Char-G / MicroSizers 2 12-06-2002 09:09 PM
Drag Strip Length ?? Dutch ZipZaps 2 10-24-2002 08:03 PM
