Old 10-19-2002, 02:53 AM
lanevo7 lanevo7 is offline
place ur tips here!!
hey guys, I'm not sure if i should start this thread here or at the mods page...but since i'm here..i guess i'll just make it here..
post all ur tips that makes ur car go faster, turn better, longer lasting, longer range...etc...whatever improves ur car...
here are my tips:
so far i've just did the crip cap removal..it did wonders for my range.
and constantly cleaning my car helps alot...so many dirt and lil dust ball get stuck
make sure ur tires are on straight! sometimes i notice that my tires are slightly wobbly..and that affects the speed..
no grease or stuff like that...it just attracts alot of dust
that's about it for me..i havne' done anything crazy like dual bat mod or dual engine or anyting like that...too affraid to try...lol
lates
Old 10-19-2002, 03:20 AM
Smurf Smurf is offline
Lube Master
Send a message via AIM to Smurf
Tips
Ok here we go...
1.) The best lube is.... PENCIL yes pencil just run your car upside down and on the spur gear just lightly touch a pencil to the spur gear do the same with the gear on the axel. DONT DO THIS TO THE PINION GEAR. If any gets in the motor it will fry it. Only do this with a 2.6 or lower motor, because with higher motor speeds it may damage the gears. After about 5 times of doing this your car will run 1mph or so faster !!! Try to re lube after every 10-15 runs.
2.) Heating up before races....
Before i do anything if my car has been sitting for over 5 mins i always turn it upside down and run it till it dies then it will be nice and warm and you will get better proformance next run.
3.) Cripple cap and pots mod.
Pots mod can get you upto 5 feet more range, the cripple cap gave me 40 feet more range also. (one thing with cripple cap is that sometimes after its done for your car to respond you have to hold your finger ont he antenna LIGHTLY then you will get some RANGE)
4.) Antenna modifacations...
You wont belive what taking the pcb cover off and untying the knot under the pcb and giving you 1-2 cm of antenna will do it will give you anywhere from 1-5 ft extra range. If you want to replace your antenna just use Cat5 wire.
http://www.halffull.net/phast.jpg
Phear my phast motor icon!
Old 10-19-2002, 05:10 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
-to make your car a little lighter without making it look ugly...cut out the side windows with an exacto or other means
-heh put tape on your fingers so u dont cut yourself accidently
Old 10-19-2002, 05:15 PM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
Lighten the car! Take sandpaper or a dremel to the inside of the body and sand out a good 15% of the interior thickness. You'd be surprised how much plastic is in there. Will the car be easier to break? Sure, that's the price you pay for speed.
Reduce reciprocating mass on the wheels! Use a tiny flathead screwdriver to 'cut' 4 of the 8 spokes out of each wheel.
Painting your bit? Always prep the surface first; the paint will stick much better. Get some 800-1200 grit sandpaper and lightly sand the entire surface of the car. You'll find that your paint sticks much better.
Old 10-19-2002, 07:53 PM
AudiTF's Avatar
AudiTF AudiTF is offline
Evo VII
Send a message via AIM to AudiTF
Go
-If you have a dog don't leave your body on the floor. My brother did and my dog took it and chew on it.
-Never ever get bored with a black permenant in your hand. You'll end up pating ur body.
I know these are common sence but still
________
Toyota Gt-One History
Old 10-19-2002, 10:15 PM
ok i read this tip somewhere...but instead of using the car battery..use like 2 or 3 watch batteries??? u don't have to charge them and they last for awhile and also lighter...but i dno't know if that works
Old 10-19-2002, 10:17 PM
oh, i saw a video clip of a dual batt mod...and dang!! it's fast!!
the car was doing wheelies and also went thru a loop!!
that's some pretty good stuff!
Old 10-20-2002, 12:09 AM
Yaksha's Avatar
Yaksha Yaksha is offline
BitLeague STAFF
Send a message via AIM to Yaksha
Be careful when racing on tiled surfaces. If you're running a high end motor, regardless of your tires, you will lose control every so often, so be very light on your turning controls.
Every so often you should remove your rear axel and clean off the gunk that builds up inside of it, also while your axel is off, you should run your motor without it for a couple of minutes, this "stretched" my motor out and really helped my speed in the next race, for Dra-G racers, this is a must.
Sincerely,
Yaksha
Xmods Honda Civic. Mixed body-kit
Old 10-20-2002, 10:28 AM
catman25 catman25 is offline
here's the pics.
Old 10-20-2002, 10:29 AM
my bit and zip was worm down at the rear axel..i pick the car up and the axel would just lay there..total loss of speed..here's my solution..get a rear axel ratio you want to keep cause i dont suggest trading anymore...get a small tip soldier and let it heat up for ten min..and unplug it for about four so its still hot to heat plastic but not burn it..take the axel out and see the little notches the axel "snaps" into..place the tip right below it..what does it do?messes every thing up if your not carefull!if you are carefull it heats and bends plastic up toward the notch and almost gives a half circle of protectionremeber less heat better and less you do is better (gotta make sure your axel snaps into place and it free rolling.this works better than foil as foil can cause more friction.and remeber less is better
Old 10-20-2002, 11:43 AM
here
Old 10-20-2002, 11:49 AM
another one
here's the last one
Old 10-21-2002, 01:21 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
another small tip:
every once in a few weeks or so...take apart your steering...and take the steering spring out ..
use some tape and to take off all the junk that gets stuck to the magnet that messes up your steering...
youll be surprised as to how much stuff does get stuck on it...
Old 10-21-2002, 01:59 AM
henry's Avatar
henry henry is offline
13B REW
landevo7 where did u see the video wit the duel bateries at? i will really lovve 2 see that.
Old 10-21-2002, 09:00 PM
hey, heres the site for the dual batt mod videos
http://www.geocities.com/pfabersac/bitsupercharg.html
radioshack racing series tips 10_second_supra XMODS 24 02-22-2004 11:32 PM
traction tips aero528 XMODS 19 11-20-2003 08:25 PM
A Great Place For News And Tutorials. Pietak440 Bit Char-G / MicroSizers 12 03-19-2003 08:31 AM
