08-28-2005, 01:18 AM
gen 3 xmods no joke
brand new news for the gen three xmods
1.new chassis setup:better suspension,engine mounted to side,battery pack on bottom,bigger servo motor, clip for new bodies to be used on old chassis,circut board one piece----- top
----bottom
----circuit
-----front suspension
-----back suspension, engine mount
2.new upgrades:body kits,lift kits,lowering kits,better suspension,turbo,better lighting, more underglow colors,new motors with switchable pinion gears and gears(with more tourque for us drifters),truck wheel kit, more wheel upgrades,new awd ------
---awd kit
----racing suspension
----truck engines
3.new cars and trucks: escalade,f150,g35,mitsubishi evo8,firebird,06 mustang (christmas time).
post any new news you hear about
08-28-2005, 01:21 AM
("\(0.o)/") Rawr!
OMG what the heck is wrong with u!? can't u read!?
look what you've done ur double posting is sooo bad u made me comeback just to correct u
Xmod Parts Help
08-28-2005, 07:44 AM
Thrasher
Nice clear pictures, Could be used in the "New Xmods" thread though.
08-28-2005, 08:13 PM
Yeah, no offence dude, but we already knew most of this stuff. I say we merge this thread with the "New Xmods" thread. I can't believe you didn't see it there.
08-28-2005, 09:16 PM
sorry every bodie i didnt see that post becuz i waz too excited but i will repost pics in "new xmods" on your command i didnt mean to doulbe post either
08-29-2005, 12:02 AM
No problem man, it happens to the best of us.
09-02-2005, 12:58 PM
How much is the new geration 3 xmods?
ye ai was just wondering if theres a price diference in the generation 3 xmods?
*Yellow Nissan SkyLine*
Stage 2 blue (11t) ~ Spinbrush Motor
AWD
stretched springs in the rear
head light and rear light set
neon under glow set
crazy glued stock tires and drift
6 cell -- sweet
ball bearing upgrade
09-02-2005, 08:28 PM
they're 10 bucks more. ill be buying one of these before i go for the disgustingly overpriced 4wd miniz. the mini z battery configuration blows chunks compared to this.
09-02-2005, 11:29 PM
by the looks of the new generation models they look less upgradable, by and they look much heavier, are they faster or anythign major then the old models or is it anythign special?
AWD
neon under glow set
6 cell -- sweet
09-03-2005, 01:56 AM
Thrasher
This new chassis to me looks like it is better at planting those rear tires. With the motors torque being put to use. My old Xmod was very good at lifting that one rear tire and just set there spinning it. The suspension on this new one look's better at keeping the tires straight up and down too. Also note the AWD upgrade kit has the center shafts in it, this I see as when you use the AWD the car is going to be slow as a snail. It is less parts to get moving for the rear drive only.
I have to also agree with the AWD Mini Z chassis weird battery arangement, but the upside here is it allows the motor to be put lower in the chassis.
09-03-2005, 08:19 AM
what do you mean by saying that theres more parts to get moving. the mini z has the same setup. i actually think this was a much better idea than the previously stock setup. to run RWD, the shaft was still included, putting more strain on the motor. now you will only use the shaft in 4WD.
09-03-2005, 09:44 AM
thanks for the info
AWD
neon under glow set
6 cell -- sweet
09-03-2005, 10:36 AM
Thrasher
I was looking at the old Xmod to the new Xmod. Your old one has the center shaft for the motor to work against to get moving. The new one that shaft is in the AWD kit, so I guess with it not in the chassis the rear wheels get more power from the motor. The downside is you upgrade it to AWD it puts more load on the motor. Look at the AWD kit picture above, I am just guessing it isn't in the car or it wouldn't be in that kit. Also the wheel bearings/bushings on this new chassis is huge next to your older Xmods chassis, if you stick with the bushings you will have a ton of drag.
I didn't say anything about it to a Mini Z.
09-03-2005, 01:48 PM
Oh, OK. I guess i just took when you said "slow as a snail" that the 4WD Mini-Z is superior in its shaft design. No Worries.
I for 1 am fairly impressed with the new design, no more negative camber when the rera suspension is depressed, the steering has been drastically improved. Supposedly, its better then the old Xmod w/ the tight turns upgrade. And, it looks like you'll be able to run a light kit, and an underglow simultaniously (not that I'll do that).
09-04-2005, 12:31 AM
Thrasher
duwain, thanks. That "negative camber" on the older one has me thinking more lego set than RC car.
In some ways the new one is more upgradeable. I like the motor set with the separate pinion gears. This alone is way better than fussing with the brass pinions on the older upgrade sets. Also makes it way easier to slip a bearing case on the motor too.
One of my biggest question is the steering servo. I have seen posts saying it is improved. I'd like to know what all is improved? How tight? More responsive? It already look's like a better car "out of the box", with a few welcome additions "down the road" so to speak.
