Old 07-29-2005, 01:14 PM
nazcom_101's Avatar
nazcom_101 nazcom_101 is offline
Custom - Hood Hinge Tutorial
Tools List:
Junior hacksaw
Rotary Tool Kit
Super – Glue
Step 1:
You will need to get hold of a metal hinge watchstrap latch, like the one next to the watch in the blow image. You can buy the hinge part, on its own from any watch repair shop…
Step 2:
Once you have got a metal hinge, you will need to remove the hood and front bumper from you Xmods.
Step 3:
Now using a Junior hacksaw you will need to cut the metal hinge to size, the size(s) will depend on what type of Xmod u have, the longer side will be glued to the underside of the hood and the smaller part of the hinge will be glued on to the front body shell…
Step 4:
After cutting the hinge to the size u will need, take the body shell and using a rotary handy drill, grind out a place for where the hinge will be glued too, allowing for the front bumper to be reattached flush, with the front body panel.
Only taking away a bit at a time, and checking to see if the hinge will fit right.
Step 5:
Now come's the time to start gluing the hinge in place, starting with gluing it to the underside of the hood. I would use some very strong super glue, that will start to dry in a few minute’s for this as use you are gluing metal to plastic…
Please make sure that the hinge will line up with the cut out in the front body panel before gluing in place. A good idea is to tape the metal hinge to the front panel first, then place the hood on the car and mark where it needs to be glued from the underside of the body shell.
Step 6:
After the glue has hardened and the metal hinge is fixed to the underside of the hood, your will now have to glue the other half of the hinge to the front body panel. Once you have done that and the glue has set hard you can trim of any excess glue from around the hinge and reattach the front bumper.
Old 08-03-2005, 11:52 PM
tec9east tec9east is offline
i did it a different way, i went to a hardware store to get small metal hinges and glued two of them together and glued that to the hood at the body
Old 08-04-2005, 04:05 AM
nazcom_101's Avatar
yer... trying different items and ways of putting them togther is the best way of making your own custom parts... nice job on that hood hinge... it look well sweet... keep up the good work...
Custom Mustang hood scoop color? LBRC XMODS 15 10-17-2004 03:28 PM
Custom S2000 w/CF hood (link to pics) MicroSpeed Bit Char-G / MicroSizers 13 03-14-2004 01:47 PM
Custom S2000 with CF hood MicroSpeed Bit Char-G Gallery 21 01-19-2004 12:44 PM
Custom EVO. (Body from Skirt tutorial.) Bad Company ZipZaps 14 12-20-2003 01:24 PM
