Old 05-07-2005, 02:39 PM
T Man T Man is offline
Front suspension in rear
I don't know how much interest there is in X-Mods anymore; I personally have put mine aside to fiddle with my Mini-Zs, but I just thought that I would post one of the latest products of my tinkering.
Ever since I got my X-Mod, I hated the rear suspension (probably because I've been spoiled on 1:10 cars). The extreme amounts of negative camber that the car gets when the rear suspension is compressed is ridiculous, so I decided to fix that.
I wanted to use as many stock X-Mods parts as possible, so I started with the front 4wd conversion kit. I don't have the time to go into a lot of detail now, but it wasn't really that hard; it just required a little bit of thinking skills. I will need to go to RadioShack to get another 4wd kit since most of the parts of my original one are in the rear of the car.
But enough of that, I'll let the pics explain it for you:
Old 05-07-2005, 02:42 PM
Old 05-07-2005, 02:43 PM
Old 05-07-2005, 02:44 PM
4; last one. I will post more as I start rebuilding it or if anyone wants to see it from a different angle.
Old 05-08-2005, 11:53 PM
JustinL42
t-man,
Looks like you did a good job. I have thought of doing this but kind of got distracted by my Iwaiver 02/mini-z as well. Any impressions on handling improvements? Did you bolt the bottom triangles (knuckle holder) straight through to the front towers on top?
Thanks,
JustinL42
Old 05-09-2005, 12:35 PM
Originally posted by JustinL42
t-man,
Thanks,
JustinL42
Thanks. I won't be able to assess handling for a while because I have a few new parts to get in order for it to run.
I'm not quite sure what you're asking about the bottom knuckle holders. Rephrase your question and I might get it.
Meanwhile, I got rid of all of those ugly white pieces and replaced them with CF parts. Right now, there are two pieces on the bottom, but I will eventually integrate them into one piece of CF.
Old 05-09-2005, 12:36 PM
Old 05-09-2005, 12:38 PM
And for those of you who have looked at this and noticed it, yes the car is quite a bit wider now. It won't mix well with the X-Mod bodies (which I don't plan to use), but it might provide more stability.
Old 05-11-2005, 09:54 PM
xmodders
Nice job. I ben selling kits simular to this for some time now. i made a custom rear pod at my work on a cnc from delron and it uses a toe in and out system like the schumacher sst.
im selling the kits $25 for total rear end "no bearings tho." just strap on a motor and put it on. if you want a link to the site just check the offical xmod fourms its poted by a few people on there becouse im not 1 to go on outher peoples fourms pramoteing my site. and i like tiny rc alot of good info on here.
Old 06-02-2005, 07:33 PM
duwain
question, how did you cut the carbon fiber?
Old 06-04-2005, 12:53 PM
I used a Dremel. If you want to do some for yourself, wear a mask; when you cut it, it produces a large amount of fine carbon dust that you don't want in your lungs!
Old 06-04-2005, 02:15 PM
duwain
yeah, i think i will. ive never handled carbon fiber, so i dont know how strong it is. ive got a dremel. im thinking about getting another xmod. the one i now is shot to crap. i like the idea. good thinking.
Old 06-06-2005, 12:33 PM
duwain
where did you buy your cf? i cant find any anywhere. and thats 1mm right?
Old 06-06-2005, 11:58 PM
Sinni Sinni is offline
if i were to guess he got it out of the clear chasis upgrade available at radioshack.
But if u were looking, try asking local custom stereo shops if they have any scraps laying around.
Old 06-27-2005, 05:35 PM
jamgunner jamgunner is offline
Wannabe TinyRC Pro
Send a message via AIM to jamgunner
nice work! from the first time i got my hands on one i had wondered why they were not made this way to begin with...
Mounting Mini-Z bodies on Xmods neurokinetik XMODS Mods and Projects 18 12-28-2005 05:13 PM
Rear suspension upgrade idea... neurokinetik XMODS Mods and Projects 2 12-29-2003 02:24 PM
Rear suspension on a bit? chelboed Bit Char-G Mods and Projects 28 04-13-2003 09:51 AM
ZZ rear axle wheels on front of BIT? Also willing to buy a set of front ZZ wheels. SPEED Bit Char-G / MicroSizers 0 09-27-2002 06:40 PM
