Old 04-11-2005, 02:04 PM
njdevsfan2487
servo horn problem
It seems that the servo horn is slightly loose eventhough I have the screw all tighten and what not. This looseness cause the car to turn slighty right as the left front tire points inward due to the servo being loose. Is there anyway to fix this?
Old 04-12-2005, 10:04 AM
Capt.ArD Capt.ArD is offline
i've never heard of this happening, but if you can get some small washers or wheel shims, put one or two on the screw so that it gets better contact with the horn. hope it helps.
skyline, black
Spinbrush motor with capacitor mod, 10-tooth pinion, blue spings, 3.0 tie rod, lego tires, AWD. Plastic driveshaft.
rally!
Old 04-12-2005, 10:50 AM
njdevsfan2487
i dont think that will help because i believe its loose from the inside
Gen 1 Servo to Evo Elec Compatibility Jshwaa XMODS Mods and Projects 0 02-18-2006 08:50 AM
Servo, Steering problem Xtreem XMODS 6 07-25-2005 08:36 PM
gap between tie rod and servo horn jamgunner XMODS Mods and Projects 3 07-24-2004 02:53 PM
Verticle Mount Servo crusader4x ABC DTM Parts and Hop-Ups 10 02-04-2003 03:55 PM
