Old 03-28-2005, 01:58 PM
I-luv-Goin-Fast I-luv-Goin-Fast is offline
Rear Axle Bearing
So, I remember seeing something like this somewhere. First, get a little piece of tube and put it on your rear axle. Then, you drill the spot where your axle goes so that the tube will fit. Third, you fill the tube with grease and put your axle in its spot. Finally, you either glue or jb weld the tube in place.
Shane
Repairing a worn rear axle retaining slot rfnagel ZipZaps 5 01-22-2004 01:37 PM
Rear Axle Tip nrmcj Bit Char-G / MicroSizers 8 05-18-2003 01:47 PM
heres a simple solution incase your rear axle doesn't snap into the mounting points spikeymike218 Bit Char-G Mods and Projects 18 02-16-2003 09:24 PM
ZZ rear axle wheels on front of BIT? Also willing to buy a set of front ZZ wheels. SPEED Bit Char-G / MicroSizers 0 09-27-2002 06:40 PM
