03-26-2005, 11:04 AM
axle help
on a bit should the out side wheel ( the back axle wheel wiht out the gear) run not completely on? im say like sould the wheel move if i held the axle and move the wheel? like the car has a differintial? if not how can i take the wheel off? see my car dosent run strait ( and i have fixed with the front part ) and i think its the back axle.
Mr.M new and improved no lie'in
03-26-2005, 03:33 PM
Tiny RC Pro
yeah. It is the back axle causing it. I am not sure why they do that but they do. I fixed mine with super glue but I would probably just go buy another axle if I could have at the time (before microsizers came out in the US)
Best bet would be going out to buy a new axle set.
03-26-2005, 04:32 PM
no , ive got some glue thats expensive but its worth it. I'll just fix it with that and it will be good as new ... or .. umm like how it should be
03-30-2005, 02:30 PM
BitPimp Enforcer
Why ?
Just glue it!
Don't try to glue it with the wheel on.
Twist and pull the wheel off, put a small drop on the wheel then replace the axle and let set til dry, install in chassis and you're good 2 go!
DarkTari
If It Don't Fly....."MODIFY"!
03-30-2005, 03:19 PM
Tiny RC Pro
Mostly because It is so dang hard to pull the wheel off. I couldn't get it off but I used one of those fine tip super glue thingys.
Do whatever you see fit.
03-31-2005, 06:14 PM
but i did what DarkTari said take off the wheel and but glue on it and it is solid on the axle.
03-31-2005, 08:27 PM
BitPimp Enforcer
Ding Ding !
DarkTari
07-23-2005, 04:41 AM
dont listen to dark tari hes gay/
07-23-2005, 10:53 PM
BitPimp Enforcer
See Ya Slick
DarkTari
07-26-2005, 11:06 AM
BitPimp Enforcer
Yeah Right
DarkTari
