03-06-2005, 02:49 PM
My wiring dream/nightmare...
Hey guys... It's been a long time since I last posted... I've been workin on my car for quite a while now, ever since I got it last Christmas(Christmas of '03)... I'm hooked, what can I say... I've been checkin the boards every day since I found the site, and I'm impressed... You guys have brought some complexity and just plain coolness to Xmods that wasn't there before... I for one, can't stand people who play-up basic upgrades that any rich snot can buy... No, I like the kinds of mods where you have to think, and actually use your hands to make something really incredible... Now, mind you, this thing is only about 40% done as of now... I've got most of the basics down, upgraded motor, all wheel drive, and my favorite... The custom HotSwap lighting kit from Ebay... I waited anxiously for that thing to arrive in the mail... Foglights AND a tailpipe light... But I wasn't happy... So I did a ton of splicing, cutting, and rewiring, to bring you this...
2003 Acura RSX
BASICS:
Stage 2 Drift Motor
Hard Suspension All Around
All Wheel Drive Upgrade
Hard Slicks All Around
Chrome Wheel Upgrade
CUSTOMS:
HotSwap Lighting Kit with custom installed dual head/tail lights + Ocean Green Fog Lights
Custom Flat Black Hood Scoop
Aluminum Lug Nuts (Ask me where I got em :-p)
Custom Nitinol Antenna
SOON TO COME:
Ahh, the possibilities are ENDLESS with Xmods... Hmm... Well, it's a functional NOS system, with as much voltage as you want to can fit under the hood... Totally controlled by the remote... ;-)
03-06-2005, 02:52 PM
Real End
The back was especially difficult because it's such a tight space, and as we all know, the rear holes are bigger than the actual lights, which make it hard to keep em in place...
2003 Acura RSX
BASICS:
Stage 2 Drift Motor
CUSTOMS:
SOON TO COME:
03-06-2005, 02:56 PM
Like I said, a nightmare!
Out of everything, getting the wires to stay put was the hardest... I found when doing the outer lights, the ones directly above the wheels when the body is on, rub on the wheel, and I spent days trying to figure out how to keep that from happening, and still giving me some suspension play in the front... I finally broke down and got my dremel out... After making the mounting hole on the body lower down, I put some heavy tape on the top of the mounting hole, so it would be a tight fit... It's hard to even notice that the front is raised up, but it does a world of difference underneath...
2003 Acura RSX
BASICS:
Stage 2 Drift Motor
CUSTOMS:
SOON TO COME:
03-06-2005, 02:59 PM
Ok, my ranting is done...
I want to end this with a picture of my custom hood scoop... I know, it's honkin big, but that's what makes it cool! I'm considering running the unused tailpipe light into it and makin it light the road! Believe it or not, I got it off a 1/25 scale model of a Mercedes race car... It fit like a dream on the hood, or the roof... The color was right too, but after I screwed through it with an oversized screw, I had to sand it down and paint it... I think it looks good, I don't care what nobody else says! :-p Ok, I'm done... Critique it however you like... Thanks for your time guys! ;-)
The Ugster <---|
2003 Acura RSX
BASICS:
Stage 2 Drift Motor
CUSTOMS:
SOON TO COME:
03-06-2005, 09:26 PM
Too many XMODS
Looks great, man. Nice job on the lights. I always a dab of glue when I put the lights in.
Anyway, you ought to switch to Li-Ion batteries now to run all those lights!
Here is one of my chassis...
RSSJIB
(2) Yellow Skyline GT-R: AWD, AtomicMods 180S motor, Li-Ion, CF driveshaft, suspension, bearings
(2) Black Skyline GT-R: AWD, Stage2 motor, Li-Ion, suspension, bearings
'04 Mustang: AWD, AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: stocker
(3) STi WRX: AWD, CF chassis, AtomicMods SS130, bearings, body kit, Li-Ions coming
Black RSX: AWD, Stage2 motor, suspension, bearings
Silver RSX: stocker
Red Supra: AWD, Stage2 motor, suspension, bearings
Silver Supra: body kit, Li-Ions soon
(2) 350Z: body kit, Li-Ions soon
NSX: body kit, Li-Ions soon
'65 Mustang: body kit, Li-Ions soon
_________________________
"rehab is for quitters"
03-06-2005, 09:48 PM
Nice ride...
[b][size=1][font=times new roman][color=green]Man that is sweet! It's so clean and professionally done! Yes, I've wanted to do Li-Ions for a while now, but they seem so high maintenence for me... I have a few questions about those, if I may...
Do you need to build a charger, or is it possible to buy one?
Is it possible to get a cell setup equivalent in voltage to a 5 or six cell setup without being impractical or cutting down run time by much?
Thanks for the comments, and keep that thing cool... Literally :-p
-Ug
2003 Acura RSX
BASICS:
Stage 2 Drift Motor
CUSTOMS:
SOON TO COME:
03-07-2005, 07:03 AM
Too many XMODS
I bought the cells and the charger from AtomicMods. He has a couple of different chargers...I bought the $20 one, and it works just fine. It will charge the cells in about 30 minutes.
The cells alone are $8.95 ea. No too bad. And you only need two. They are AA in size. They are also more powerful than a 5 or 6 cell setup. Plus, the weight savings is there as well. Have you tried to fit six cells under your car body? It is not easy...
Anyway, the wiring harnesses I made myself. I found some Deans connectors online for $1.40 per pair. I can solder pretty well, so those were not too bad. If you don't like to solder, AM sells the wiring harnesses as well. There is a tutorial on AtomicMods.com on how to install the Li-Ions. It is very detailed. I have four Li-Ion cars now out of the twelve that I have.
(Jeez, I have too many)
But anyway, you will freak out when you run the Li-Ions. The speed is pretty amazing, especially if you combine it with a different motor. I have two cars with an AtomicMods SS130 motor, and it rocks. The first time I fired them up, the tires blew off the rims!...No kidding! If you need any more help, just ask.
Always glad to share the knowledge...
RSSJIB
Silver RSX: stocker
03-07-2005, 07:06 AM
Too many XMODS
Here is a pic of one of my Skylines with Li-Ions and A 180S Hi-Torque motor. I think I may do my RSX next...the Li-Ions will fit under there perfectly...
RSSJIB
Silver RSX: stocker
03-07-2005, 07:08 AM
Too many XMODS
My RSX
Here is my RSX...
RSSJIB
Silver RSX: stocker
03-07-2005, 01:23 PM
Whoa...
Hey man, thanks for the quick and detailed replies! I've wanted to get the black RSX, but it just doesn't make sense to me since I already have the regular one :-p Ahh well... Hey do you know exactly how much voltage those cells put out, and for how long? AtomicMods looks like a good place to start with buying Li-Ions and stuff... My soldering skills are pretty good, mostly because I've messed around with the car so much, and other soldering projects for a while... Practice makes perfect... Or melts plastic and/or destroys whatever you're trying to build ;-) Thanks again
-The Ugman
2003 Acura RSX
BASICS:
Stage 2 Drift Motor
CUSTOMS:
SOON TO COME:
03-07-2005, 06:23 PM
Wide Open Throttle
nice lug nutz. where did you get them?
03-07-2005, 08:15 PM
Believe it or not...
Hey,
I got them off an old tech deck bike, believe it or not... It's a nice fit... I even tried the "pegs" that come with the bike, and they fit too, though I don't know why you'd need em :-p
Ug
2003 Acura RSX
BASICS:
Stage 2 Drift Motor
CUSTOMS:
SOON TO COME:
03-07-2005, 08:30 PM
Too many XMODS
The Li-Ions put out 7.2V, I do believe....the cells that AM carries are of the 750maH variety, so you have some good run times. I am guessing at least 20-30 minutes of hard throttle...anyone else?
RSSJIB
Silver RSX: stocker
