Old 01-19-2005, 03:50 PM
stk stk is offline
Very Stiff Suspension
The guys over at Xmodspeed.com used 2 stock springs on each side to create an extra stiff suspension. Has anyone that uses their Xmod to drag tried this? Do you like it? Did you notice a difference?
Edit: Sorry here is the link. http://xmodspeed.com/dragster.htm
Old 01-20-2005, 07:42 PM
Phred168 Phred168 is offline
The front should be very stiff, and the back should be very soft. The theory is sound, though i dont know how much difference itll make.
1997 Red Toyota Supra (It finally bloody runs!)
Mods:
2 cell Lithium-ion batteries
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
1965 Ford Mustang :Bone stock
Old 01-25-2005, 12:14 PM
sporttracguy sporttracguy is offline
another way to make a stiff suspension with the stock springs is to remove the springs and streatch them to about half their length and then re install them,, worked great for me, and beats the heck out of buying those pricy radio shack springs aftermarket
Sporttracguy
Old 02-14-2005, 07:41 PM
broke ess supra broke ess supra is offline
to drag race you want less turning traction in the front and more control than anything since you are only going strait therefore regardless if you use awd or rwd you want soft to medium springs in the front and hard in the back so you get more traction with your tires flat on the ground unlike the soft springs that leave your tires at an angle
In terms of traction in awd soft springs won't affect the front grip of the tires while going strait...although if you are going rwd i would suggest using hard tires so you go as strait as possible
also turning down the steering trim on the controller helps
True FULL suspension travel Mod zzmods ZipZaps Monster Truck 13 12-30-2005 11:49 AM
Suspension Set-up chelboed Epoch RC1/43 Parts and Hop-Ups 3 12-20-2003 11:12 AM
Rear suspension on a bit? chelboed Bit Char-G Mods and Projects 28 04-13-2003 09:51 AM
Suspension Mod TEAM_NITRO Epoch RC1/43 Parts and Hop-Ups 3 11-23-2002 12:22 PM
