Old 01-19-2005, 12:20 PM
bane bane is offline
binding problem
the son and i just put a rat shack bearing kit in his nsx and now the car will hardly move. any tips or hints would be accepted. Thanks
Old 01-19-2005, 06:35 PM
Zero-Man
Remove the motor and check how the driveline spins, does it bind up? If the center shaft is not seated right it will put the whole driveline into a bind. Turn each wheel and see how it feels, trial and error will get you there
Old 02-06-2005, 05:10 PM
mastersmite mastersmite is offline
May the force be with you
Send a message via AIM to mastersmite Send a message via Yahoo to mastersmite
hmm, my NSX didn't have any trouble with the AWD, but the bearings wouldn't go on the axle all the way so i have 2 left-over bearings taht wouldn't go on.
Moege die Macht bei dir sein
Yellow 2004 NSX
Stage 2 Blue 11tooth SB hybrid
blue springs in back, yellow in fornt
AWD
Ball DIfferential
Duct-tape Autobra
Old 02-07-2005, 07:54 AM
I have a beach ball...
You most likely put the wheel lugs on too tight. This is a common mistake, so don't feel too bad if it's the problem.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
ver 2 ESC with X-speed problem miketre Mini-X 8 10-29-2003 11:27 PM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 09:24 PM
