Old 01-15-2005, 09:26 PM
clrkp clrkp is offline
Send a message via AIM to clrkp
Slot Car Motors
I recently got into slot car racing, and the motors we use to race them are the same motors we all use in xmods. Here is a site that sells good slot car motors, Look at the JK Falcon III, its turnin at 46,000RPM. Don;t have one yet, but my slot car and my XMOD will have one. The only thing is that slot cars use the opposite end we use, unless it is a shaft drive from the front. Heres the site
http://www.professormotor.com/cat_motor.shtml
Old 01-18-2005, 11:50 AM
Pocket_Rocket's Avatar
Pocket_Rocket Pocket_Rocket is offline
Very nice, question is I cant remember how much Amps a stock car can handle...
"Theres no Shame in my Game!"
Old 01-21-2005, 11:52 PM
ChenPokoMasteR's Avatar
ChenPokoMasteR ChenPokoMasteR is offline
A Winner Is You
Send a message via AIM to ChenPokoMasteR
Those slot cars are beasts....my friend has one and i raced against my xmod...and i got eaten ALIVE....those cars are just ment to go REALLY fast...and in China and stuff, they have all these TV shows about them n stuff...pretty cool!
350Z- Cf Drive shaft, Custom motor ( 40T, bbcan, Neo mags), Cf drive shaft, Awd, bearings
Skyline- Cf Drive shaft, stacked fets, 2 cell lithium, AWD, Bearings, Custom motor
Old 02-01-2005, 11:42 PM
Tbird Man Tbird Man is offline
slot car motors are made for 12v I believe, that could be a problem, also a 46,000rpm motor means NOTHING, i had a 35,000rpm okami fence racer motor in mine, and even getting twice the voltage(4batt vs. 2bat in fence racers) I didn't have the torque to even turn the wheels. RPMs are nice but they're only half the equation. and torque isn't all that either, it's when you balence them well that you can make serious power. I used a PN raceing 28t armature with a Squat ball bering motor can and magnets from a Tamiya Mach Dash mini 4wd (fence racer) motor with awsome results surpassed only by my bigger 180 motor (stock is a 130 size) also I woulden't suggest trying neo magnets with a low turn armiture, awsome torque once it starts but you often have to get it started. so after that if you don't understand what I said (very possible as I tend to ramble) in my experence the key is balence. I may try to build my own 180 size when I can and see what i can do. I will post if I do.
Nissan Skyline GTR v-spec
AWD
suspension upgrade (soft rear med front)
180 size motor, custom made heatsink
GPM alu front knuckles, shocks and center bering holders.
more to come...
Initial D is addictive zombiebaby Bit Char-G / MicroSizers 96 07-20-2003 01:31 AM
slot car mod! Spanky Bit Char-G / MicroSizers 29 06-10-2003 05:15 PM
will 1/24 slot car parts work ? catman25 Mini-X Parts and Hop-Ups 3 01-30-2003 07:54 PM
Mounting two motors connected to same gear?? Def Bit Char-G Mods and Projects 11 01-03-2003 09:37 AM
slot car motor? BMW325 Bit Char-G Mods and Projects 6 11-11-2002 01:43 PM
