Old 01-15-2005, 08:02 PM
RadRacer
Cheap Li-Ions, but are they good?
Here's the link to the Li-Ions
R these any good? If so, what's the highest mAH that you could use in a stock X-Mod?
Old 01-15-2005, 10:42 PM
I have a beach ball...
Sorry, I don't see any cheap Li-Ions or Li-Polys on that site. www.blindbatts.com has Li-Polys for $3. Go check em out.
To answer yout question about mAh, you can use as high a mAh rating as you can find, because mAh only rates the capacity of the battery.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 01-16-2005, 09:12 AM
RadRacer
O...I thought those were cheap...oh well, but you said I can use any mAH I can find, so 1100mAH won't fry my FET or anything??
Old 01-16-2005, 12:57 PM
Nope, and it will run for about 30 minutes with a stage 2.
'65 Ford Mustang
All the RS goodies
Old 01-17-2005, 04:25 PM
RadRacer
k. but how much better would they be than the 750mAH?
Old 01-17-2005, 07:39 PM
They would only run longer. There is no difference in current.
'65 Ford Mustang
All the RS goodies
Old 01-18-2005, 04:34 PM
RadRacer
well....then how long do 750's run?? Murcielago659 said these would only run bout 30 mins. 750's must only go like 15 or 20 then....
Old 01-25-2005, 09:28 PM
broke ess supra broke ess supra is offline
These cells are cheaper!!!!!!!!
these are individual lithium cells=
http://www.allelectronics.com/cgi-bi...-40&type=store
This a battery pack and charger you could probably rig up=
http://www.allelectronics.com/cgi-bi...-35&type=store
http://www.allelectronics.com/cgi-bi...C-9&type=store
Old 01-26-2005, 10:58 PM
Good find! I'll have to check those out when I finally get some money.
'65 Ford Mustang
All the RS goodies
Old 01-31-2005, 02:27 PM
Turnination Guy Turnination Guy is offline
mAh is a measure of battery life. It is litterally “milliAmps * hours”.
So, if you want a battery that can discharge:
500 miliAmps (0.5 Amps) for 1+1/2 hours (3/2 hours),
you just multiply:
500 mA * 3/2 h = 750 mAh
You can also work backwards from this figure. If you have a battery and you want to know how long it will last with a specific current draw:
1,000 mAh with a draw of 2,000 mA (2 Amps)
you just divide:
1,000 mAh / 2,000 mA = 0.5 h (half an hour).
However, the battery may not actually be able to handle a draw of 2 amps; that is another figure entirely. And just because a battery has good run time, that doesn’t mean it can handle good current draw.
What are the stats for maximum and minimum current draw? Anyone know?
is plywood a good track surface? if not, what is? and barriers,. whats good??? eman1 Tracks 6 07-21-2003 03:48 PM
Where's a good place to find a Sprinter Tueno Tune up Box bit for cheap??? SPEED Bit Char-G / MicroSizers 1 08-27-2002 01:33 PM
