01-07-2005, 08:42 PM
May the force be with you
Wtf?!?!?!!
I just got the bearings from RS and one of them won't fit over the plastic at the end or the long rear axle. This ticks me off cuz i have 2 use the bushings on that part of the axle on both sides or it will spin all over the place.
Moege die Macht bei dir sein
Yellow 2004 NSX
Stage 2 Blue 11tooth SB hybrid
blue springs in back, yellow in fornt
AWD
Ball DIfferential
Duct-tape Autobra
01-07-2005, 11:36 PM
Thrasher
I had that happen just the other day. Only I was using this shop's bearings and it was my front U-shaft, but it broke as I was sliding the bearing onto it. The other shaft fit fine, I think some parts that plastic end is thicker than others. I do not think the cause was the bearings themselves, because the same bearing fit the other shaft fine.
01-08-2005, 11:37 AM
Xmodder
Hmm, how often does this happen? If its a problem that comes around often, i might stray away from getting bearings, or can you dremel the shaft down to make it fit?
*Nissan 350z*[COLOR=royal blue]
-Stage 2 red SB hybrid motor (soon to be neo mags, BB can and BB endbell)
-IC-3 800 mAH bats - 4 cell
-AWD
-Blue springs up front, silver in back
-Aluminum locknuts at all four corners
-Locked rear diff for drift action![/color]
01-08-2005, 12:13 PM
I have a beach ball...
I've put bearings in four different cars now, and have not had this problem. It's definitely not the bearing's fault, it's more likely the cars themselves are a bit anomolous.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
01-09-2005, 09:53 AM
i think i got it
the bearings hang up on the transition between the metal axle and the plasic cup thing. i think sanding the edge down will get it on the rest of the way.
Yellow 2004 NSX
AWD
Ball DIfferential
Duct-tape Autobra
01-09-2005, 02:52 PM
Wannabe TinyRC Pro
i had a similar problem happen... twice. first set had ttroubles going on like you said. the second set had 2 bearings that were falling apart (the inside ring was pushed out). needless to say i got my money back and left it at that.
01-09-2005, 05:08 PM
They were Radio Shack bearings, weren't they? I tell everyone those are junk, and no one listens to me.
'65 Ford Mustang
All the RS goodies
01-18-2005, 10:57 PM
yea they truly are my car with the rs ones makes a metaly sound, but the other one with aftermarket bearings sounds smooth... plus they were much cheaper! also the bearings are a tighter fit the less time you keep your bushings in so if you run the bushings for awileyou might be able to fit them later
Red Supra = all traction
stg. 2 red motor
suspension, both wheel (im running ones painted white) tire, and body upgrades
speed kills: live long and drive a civic
1967 Camaro = all torque... no traction
md. rear springs and soft fronts side dual exhausts, all go no show and enough power to smoke your civic
