Old 10-17-2002, 02:31 PM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Alternates for PCB cover
Recently, I just lowered the front tab of the chassis where the body is supposed to lock into thanks to Killboy's suggestion. Problem is that when I try to fit my RX-7 body, it clashed with the PCB cover. It wouldn't go a mm further so that it could meet with the tab thus I removed the PCB plastic cover and it will fit. Currently, I would like to know about some alternate ideas for a cover, preferably short enough to mount the body on the lowered chassis. For now, I'm using a type of laboratory masking film called Parafilm to secure the board from jumping up and down.
Old 10-21-2002, 12:09 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Parafilm sounds like a great solution! Maybe try heat shrink tubing around the whole center section? Or just good old electrical tape...
Old 10-21-2002, 01:32 AM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
Good'ol electrical tape! That's what I use.. On my slammed RX-7, though, I didn't need to remove the cover.
Old 10-21-2002, 05:32 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
just shave some of the pcb cover off...thats what i did..
now its more diagonal...on the sides...instead of curved
ESC/Receiver Cover DirtTrak Micro-T Parts and Hop-Ups 2 05-28-2009 08:06 PM
Gear mesh noise only when cover is on? JackP311 Micro-T General 1 05-13-2007 09:33 PM
Battery cover set screw mod slotsurfer Auldey (All) 0 01-05-2003 01:16 PM
Is there a real, or easy proper way of taking out psb cover? pakiplaya Bit Char-G / MicroSizers 2 12-13-2002 03:40 PM
PCB cover ZIZI ZipZaps 0 12-08-2002 03:57 PM
