Go Back   TinyRC.com > 1/43 and Smaller > SuperSlicks > SuperSlicks
Old 12-27-2004, 10:03 PM
micromatch micromatch is offline
Send a message via AIM to micromatch Send a message via Yahoo to micromatch
ss fully loaded charging problems
hi i just bought my ss fully loaded and it is not charging... no light is going on or anything. please help me fix this!
l< 3 l\l T
Old 12-28-2004, 12:05 AM
xThaiTX xThaiTX is offline
alright i had this problem before an i think i know exactly wrong.
1st. r u using rechargables battery? if yes it wont work for sum reason.
2nd. are the batteries new? if its not then get new ones because those might not hold a big enough charge.
for the ssfl i dunno why but all i could use is alkaline batteries. no nicad or nimh. lets try lithiums
my name is ThaiT and no im not from Thailand
Old 01-13-2005, 09:38 PM
podunk podunk is offline
possible bad connection w/batteries
I had this same problem with both of my SS's - found the same problem on both and was able to fix with ease.
My problem was that one of the AAA batteries in the charger wasn't connecting with the charger's circuit. To be specific, it was the positive terminal on the second battery from the left (on both chargers). To fix, I used a pocket knife to wedge under the metal blade that makes up the charger circuit, then shoved the end of a toothpick under the metal to keep it wedged perminately. Works like a champ now.
Hope this helps. Good luck.
Problems charging digi-q tanks gwhtw Combat Digi Q 2 10-28-2005 02:48 AM
New Fully Loaded Motor question skyline7 SuperSlicks 1 12-06-2004 07:17 PM
charging problems ms char-ged Digi Q 8 05-14-2003 07:36 PM
fully charging zipzap stack battery CRUMB ZipZaps 3 03-02-2003 08:57 AM
