12-27-2004, 06:29 AM
Dual Cell Help!!
I have made a dual cell, but there are some problems. I charge it for two (sometimes more) minutes. But it will only drive for 5-10 secunds. Do I use to large wire or what??
Ready... set... GO... :P
01-05-2005, 10:54 AM
BitPimp
you do realize that a single cell is 1.2V, and a dual cell is according (2.4V). that means the charger on the controller is only capeable of charging one battery. a seperate charger is needed.
heres a link to a thread that you need, look at the bottom, it explains what you need.
Whack!
01-09-2005, 07:33 AM
I don't know what's wrong with that, but you may be able to use a charger made for 2.4V. A Zipzap monster truck controller should fit it if you hold the bit down with a rubber band.
Also, one of the batteries may be dead or damaged from the soldering, or the PCB may be fried.
01-19-2005, 10:16 AM
Are you sure that you put insulator beetween battery and terminal ? If you didn`t, one of your battery is short-circued ....
