Old 12-21-2004, 01:08 PM
xmod456 xmod456 is offline
best zipzap
i am buying a new zip zaP AND I DON'T KNOW WHICH ON TO BUY ZIP ZAP ZIP ZAP SE ZIP ZAP MONSTER
Old 01-11-2005, 02:42 PM
kehern15 kehern15 is offline
also, the new SE practilly fly.
Old 01-11-2005, 07:16 PM
damootch's Avatar
damootch damootch is offline
I agree. I have Ford Mustang Mach1 and it is 10 times better than any of the earlier SEs I have. Much Improved!!
IF you can afford it get one of each:
A SE
A monster truck
And an oldschool ZipZap
They are all fun!
-Mootch
Old 01-12-2005, 06:07 AM
A SE
A monster truck
They are all fun!
yep, i have a SE, and a monster. i have no need to get a regluar one.
Old 01-13-2005, 10:22 PM
codesuidae's Avatar
codesuidae codesuidae is offline
Send a message via AIM to codesuidae
The new SE's have 80% more power than the original SE's.
The original SE's powered the motor with a maximum 30% duty cycle. The new SE's use a 54% duty cycle (that is, they turn the motor on for a maximum of 54% of the time, the other 46% of the time the motor is off).
With my DC Mod the motor is powered at up to 100%. That is, the DC mod allows the original SE to deliver 333% more power to the motor, and allows the new faster SEs to deliver about 185% more power.
I've set the power curve up so that most of the speed steps are at lower powers, and the last two make steep jumps up to 100%. This gives the car good control on the low end while still allowing it to deliver full power on the high end.
Old 01-16-2005, 08:44 AM
bdnunchaku
You mentioned in another post that this DC mod is superior to the mosfet mod for the SE's. Can you do a similar mod for non-proportional bits? Would it outperform a mosfet modded bit?
Old 01-16-2005, 06:40 PM
codesuidae's Avatar
I don't know for sure, its possible. Some bits and clones use a 50% duty cycle so that they can have a turbo button. If the turbo button was not added its possible that the motor is still running at 50%. If it uses a CoB construction (black epoxy dot on the board instead of a big black chip) it might not be possible to turn the turbo on. In that case a mod like the DC mod might help.
In the case of the ZZMT, it already uses a 100% duty cycle, so it wouldnt' help there.
zipzap and zipzap se? xmod456 ZipZaps 8 01-24-2005 04:11 PM
just went through my parts box....... airbob20 For Sale/Trade 10 01-25-2003 11:21 PM
Zipzap motor and PCB dtmracer ZipZaps 4 10-17-2002 05:01 PM
BitDra-G reg. times for the ZipZap in! QFM Racing QFM Racing Customer Support 2 10-02-2002 01:09 AM
BItDra-G times recorded for 2.4v ZipZap QFM Racing Bit Char-G / MicroSizers 13 10-01-2002 09:15 AM
