12-20-2004, 11:32 PM
Drifting tips
Any one out there willing to share tips on how to set up a drift xmod? So far I have a skyline w/ bodykit and drift tires. Planning to get 4wd and 2nd stage motors. Any comments?
12-21-2004, 12:19 AM
cut = custom
thats the setup im pretty much runnin . except i got a mono shock in the rear yellow springs all the way around and SB mags in the motor
12-21-2004, 01:07 AM
I have a beach ball...
http://www.starterupsteve.com/swf/posting.html?
Replace "Steam Forum" with "TinyRC Forum" and you'll get the idea.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
12-21-2004, 07:27 PM
A Winner Is You
Also counter steer while your drifting
350Z- Cf Drive shaft, Custom motor ( 40T, bbcan, Neo mags), Cf drive shaft, Awd, bearings
Skyline- Cf Drive shaft, stacked fets, 2 cell lithium, AWD, Bearings, Custom motor
12-22-2004, 12:00 PM
here u go
i would say that if ur using an xmod u will have a hard time ripping the wheels off for a peel out so i would say get the drifting kit from radio shack and find the motor with as much torque as possible i heard the spinbrush mad works but i never tried since i am upgrading to mini z i will have to change this technique but wen i first started i did it on hard wood floors that i cleaned before starting:
step 1: clean floor
2: set up your car(super torkey motor, hard tires or taped tires, and a hard suspension in back and soft in front)
2: start out by doin single turn drifts for practice, as you come into the turn let off the gas about half way.
3: while your slinging around the turn with the momentum of the car at half throttle press the throttle all the way.
4: after you reach the point where you want to stop drifting let go of the throttle a little and the tires will regain grip.
5: coast out of the turn slowly accelerating and ur done!
DO NOT AT ALL PUT IT IN REVERSE!!!!! drifting was made so u dont loose too much speed around turns with a torky motor pressing the brakes and then gunning out of the turn will result in DONUTS.
mini z:ferrari f-40
xmod:body undecided
