Old 12-09-2004, 01:57 AM
SupraKid89's Avatar
SupraKid89 SupraKid89 is offline
Anarchy 4-Ever!
Send a message via AIM to SupraKid89 Send a message via Yahoo to SupraKid89
diy underglow
how would i go about doing this? I want to run these off a 9V with a switch.... i need about 8 LEDs
Flat Black Supra
-Engine
Stage 2 Drift motor
-Exterior
Flat Black Custom Paintjob
Blue EL wire underglow (ordered)
Command Logic Lights (x2) foglights & extra taillights...
5Zigen Wheels
-Other Mods
AWD
Old 12-09-2004, 04:22 AM
dragon4450's Avatar
dragon4450 dragon4450 is offline
customanix
Send a message via AIM to dragon4450
all you would need is a little bit of wire and the tube from a spray bottle. trim the tube to the length you want then stick 2 leds in the ends repeat as needed. then wire them all together.
and then we added the giggle gas.
Old 12-10-2004, 07:34 PM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
i'd use button cell batteries instead of a 9V. the 9V would be big and heavy. a few button cells would be lighter with the same amont of power.
racing on pavement is for wussies.
Old 12-10-2004, 09:52 PM
SupraKid89's Avatar
Anarchy 4-Ever!
Do all i do is get a battery connector with + and - and connect the straight to the leds? no resistors?
Flat Black Supra
-Engine
Stage 2 Drift motor
-Exterior
5Zigen Wheels
-Other Mods
AWD
Old 12-17-2004, 05:53 PM
mastersmite mastersmite is offline
May the force be with you
Send a message via AIM to mastersmite Send a message via Yahoo to mastersmite
better looking way
If you have a dremel or really small drill, you can take acrilic rods (availible at hobbly shows or online) and drill out the ends of them and put the LED's inside the ends and they will light up the whole tube, it will look like real neon
Old 12-18-2004, 02:49 AM
dragon4450's Avatar
customanix
Re: better looking way
thats a good idea. i might have to try that. but its basicly the same as taking the little tube from a spray bottle.
easiest and best underglow ever bengali548 XMODS Parts and Hop-Ups 2 08-05-2006 01:08 AM
really want an underglow bengali548 XMODS Parts and Hop-Ups 7 08-03-2006 10:36 PM
led underglow inventerboy08 ZipZaps 16 01-03-2004 12:12 PM
Underglow ketis88 XMODS 0 11-04-2003 08:24 AM
New way of doing underglow Lord_Nick_D Bit Char-G / MicroSizers 4 09-23-2003 06:45 PM
