Go Back   TinyRC.com > 1/18 and Larger > Tamiya M-Chassis > Tamiya M-Chassis Parts and Hop-Ups
Old 11-20-2004, 06:05 PM
tegboi tegboi is offline
Send a message via AIM to tegboi Send a message via Yahoo to tegboi
trinity green machine 3 pro motor questions
got this motor from my school's suspension r/c car (off road dirt chassis.)
a few questions..
the specs of this motor are as said on the sticker on it.
" TRINITY 27X1"
RPM: 29.642
power: 132.9w
eff.: 74%
torq.: 158Nmm
"Nr.: GREEN 3"
im not familiar with what is good and bad for motors. this motor is on my tamiya on-road chassis that i use for drifting only. so i mostly want good torque. it says that it is a 27 turn, so meaning it has pretty good torque, but then it seems very slow for what it is..
it works, everything is there and together, it runs pretty good, but feels like it is binding somewhere, and it's pretty loud when i drive it.
the brushes seem to be holding on too tight, as if the springs were too tensioned. when the springs are on the brushes, the motor does not spin freely, when i unhook the springs, it spins freely, but with slight drag from magnetic forces.
also, i've searched around, and cant find the correct way to rebuild, or overhaul it. i've taken it apart, cleaned the magnets & cleaned the brushes.
im not sure if im suppost to use some sand paper and basically resurface the magnets, or the brushes, or anything. can i apply grease anywhere? how can i check for shaft straightness? should i get new brushes for it? what can i do to have this motor spin more freely?
thanks
iLLuSionZ of FusIon
DA fusion
i need help with my car
www.g2ic.com
Report on Motor Swap in MS Pro..... DarkTari Bit Char-G / MicroSizers 7 03-26-2003 08:45 PM
