Old 11-02-2004, 04:52 PM
99skyline's Avatar
99skyline 99skyline is offline
Question lowering help
any tips for lowering?
Old 12-23-2004, 01:38 PM
smoakbomb smoakbomb is offline
Send a message via AIM to smoakbomb
theres a post around here about how you can use credit cards to replace tabs.
Old 03-26-2005, 12:19 PM
GrandRC's Avatar
GrandRC GrandRC is offline
Ive heard that if you have some extra front rims from bits and an extra axle you can lower it pretty well. what you do is get the rims off of the pins and take off the wheels from the axle and then put the front rims on the axle.
when life gives you a battery, make something explode!!!
Old 03-29-2005, 08:19 PM
I-luv-Goin-Fast I-luv-Goin-Fast is offline
You could also heat a nail file with a candle or soldering iron and from the outside of your body slowly push the file through.
Push it above the slots that your body clips on.
Hope it helps
Shane
Old 03-30-2005, 12:32 PM
GrandRC's Avatar
or you can just use the soldering iron. i tried it and its OK.
Lowering issue spamman ZipZaps 5 03-26-2004 02:31 PM
Photoshopped SE lowering VuN86 ZipZaps SE 0 09-20-2003 01:25 PM
Lowering Jobs blownPT Bit Char-G Mods and Projects 28 03-27-2003 07:30 PM
bit char-a lowering mrcdemon Bit Char-G / MicroSizers 0 01-05-2003 06:53 PM
Lowering the Civic and Supra latency ZipZaps 3 10-06-2002 03:50 AM
