Old 10-16-2002, 01:08 PM
natedogg4674's Avatar
natedogg4674 natedogg4674 is offline
Ill choke slam you!!
quick battery question
If i do the dual battery mod,does it matter if i use the stock zip battery with a stock microsizer battery?
Old 10-16-2002, 01:11 PM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
i dont understand battery at all. but the stock ones are to differnt kind one is nimh the other is nicd your not supposed to mix em
Old 10-16-2002, 01:18 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
go_zz is correct, do NOT mix the two...
Old 10-16-2002, 01:22 PM
thanks
ok, thanks for telling me,instead ill run 2 zipbatts in parallel, ever since i did the pcb swap my run time sucks, so ill let you all know how it works out
9 volt battery as a quick charger SlackerZ ZipZaps 3 10-08-2002 11:27 AM
quick newbie question bojangs Bit Char-G / MicroSizers 2 10-06-2002 12:44 AM
