Go Back   TinyRC.com > For Sale/Trade
Old 10-20-2004, 04:31 PM
kylelucas kylelucas is offline
FS NIB TL-01 Tamiya XB FORD SVT F150 Lightning 4wd RTR Set
Greetings all-
Cheap DRIFTER.........
I am looking for $125 plus Shipping to you. READ ON for details.
I have a NEW Tamiya XB RED F150 Lightning 4wd RTR for sale. Electronics and motor factory installed. Fully assembled. Comes with Tamiya Adspec TX and crystals. 4WD Shaft Drive 540 motor.
Requires 7.2V pack, charger and AA's for TX. Tamiya Item #57702.
Tamiya says:
*The SVT F-150 Lightning is built on a precisely designed TL-01 chassis that incorporates shaft-driven full-time 4WD system equipped with quality differential gears in front/rear sealed gearboxes. This system is fitted on a lightweight yet durable monocoque frame. Responsive double wishbone suspension system with four friction dampers ensures a smooth ride even over rough surfaces. Requires a 7.2V battery and charger.
Specifications
Chassis Type: TL-01
Scale: 1/10
Length: 18.23 inches (463mm)
Width: 7.24 inches (184mm)
Wheelbase: 10.12 inches (257mm)
Front Tread: 6.18 inches (157mm)
Rear Tread: 6.18 inches (157mm)
Weight: 2.29 lbs. (1038g)
Chassis: ABS Monocoque
Suspension: 4 Wheel Independent
Damper Type: Plastic coil over friction
Drive Train: 4WD shaft drive
Gear Ratio: 7:96:1
Differential Gear System F/R: 3-Bevel Diff
Transmission type: Shaft drive mid-ship full-time 4WD
Differential Type: Bevel Gear
Engine: Electric 540
Speed Controller: 3 Step F&R Mechanical
Wheels & Tires: Chrome 5 spoke/radial
Tire Diameter F/R: both 64mm
Tire Width F/R: both 27mm
Body Type: Polycarbonate Cut & Printed
Radio: 2-Channel Pistol (included)
Power Source: 7.2V battery (not included)
I am looking for $125 plus Shipping to you. I charge exact shipping per your preferred method plus insurance (per your request).
This truck set is NEW and has never been removed from package.
The box has one tear and the clear cellophane window is gone from package. The body shows slight dulling on a small area where cellophane came off and rubbed during shipping (not that this matters if you are like me - it will take a few battery packs and that will be the best remaining part of the body).
Got this at a hobby shop closeout. Would make a GREAT gift or spare for yourself. Very upgradeable. See Tamiya site for all specs. MSRP $312. Seen online for $179++. GET IT CHEAP FROM ME.
Drop me a line.
Thanks.
-Kyle
Email me direct: kydawg1@yahooREMOVE.com
(Remove caps from my email address)
Old 10-28-2004, 12:30 AM
newbitowner's Avatar
newbitowner newbitowner is offline
how fast does it go?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 10-28-2004, 06:39 AM
I do not know. It is new in box and never ran.
You can make it as fast as you want. Add a ESC, a low turn motor and bearings and you will have a rocket
FS: Brand New Micro RS4 RTR set, DigiQ DRS-04 RX-7, DigiQ DRS-03 Pitworks Skyline bluemax_1 For Sale/Trade 7 06-18-2003 12:40 AM
