Old 10-14-2004, 12:56 AM
sporttracguy sporttracguy is offline
Wider rear tires
Sorry, no pictures today, maybe tomorrow though. Im curious, do they make larger diameter and wider tires/wheels for the xmods? I have a supra and i thought that the tires just dont stick out enough in the back. I just fliped the wheels inside out and they stick out much better. Doesnt seem to change the handling much but it looks alot better.
I tried to do the same to the front as well but the wider stance hits the wheel wells and i dont want to trim them,, so for now, just the back wheels are wider
sporttracguy
Old 10-14-2004, 09:22 AM
bugman72's Avatar
bugman72 bugman72 is offline
Xmoddin' Freak
Try getting a set of wide offset wheels and tires for a Mini-Z and then go to microracers24.com and get a set of Xmod wheel adapters from Sven. I'm waiting on my Mclaren wheels and tires to come in, but I already have the adapters. Installation should be a snap. Just by adding the adapters to the Mini-Z wheels (even if the wheels are the standard "narrow" wheels), you'll add 1.5mm of offset to your Xmod's track. Add to that the 3mm offset for the "wide" Mini-Z wheels, and you've got at least 4.5mm, if not more, of added track width. Wide enough to fill any wheel well.
Greg
Red Supra/New Beetle RSI, AWD, Full Bearings, Team Orion Micro RS4 Stock 180 (10 tooth), Team Orion Micro RS4 Stock 180 (20-tooth), Carbon Fiber Driveshaft by Sluggbug, Metal Lock Nuts, Lithium Ion batteries from AtomicMods.com.
Old 10-14-2004, 07:38 PM
here are some quick shots of the wider rear tires
Old 10-14-2004, 07:39 PM
another view
Old 10-14-2004, 07:40 PM
last shot
Old 10-14-2004, 07:42 PM
oh, one more thing, this is off topic but i purchased a set of 4 stage 2 motors and i only needed the red one so im selling the others on ebay,, starting at $4 each plus $2 shipping
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
There is a link to one of them, the others are there too
sporttracguy
Old 10-14-2004, 09:41 PM
SHIFT_DRIFT's Avatar
5Zigen
Reversing wheels is an old trick.
BTW they're not wider, they have a more offset;
since the width of the tire is the same as usual.
Try And Sleep Now.
DRIFT my ANTI-rice
Old 10-15-2004, 09:02 PM
hotrod29728's Avatar
Sporttracguy I will send you the cash for it if you will send me the Yellow motor... I am getting more into these pinions (Yellow&Red) and believe they actually help the car more than the other ones...
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Old 10-20-2004, 08:08 PM
hotrod,
they are still on ebay right now at those links,, just bid and its yours
Found a new set of tires that will fit stock rear bit rims... Driven_out Bit Char-G Mods and Projects 0 02-06-2003 07:26 PM
