Old 10-05-2004, 08:41 PM
truckian's Avatar
truckian truckian is offline
Playstation Controller
I thought that maybe it would be possible to modify a PS2 controller to control a TTTT by adding a transmitter. So is it possible.
Old 10-06-2004, 12:23 AM
Thorsten Thorsten is offline
Hi Truckian,
all you need is a variable resistor. It should have nearly 5 kOhms. This one you can use in a radio transmitter or in a infrared transmitter circiuit.
I don't know your special PS2 controler, but if it is an analog controler an the "axle-resistor" are 5 (or up to 10) kOhms, so it should work.
best regards
Thorsten
www.mikromodell.de
Old 10-09-2004, 02:25 PM
truckian's Avatar
I just have a standard controller with the two analog joysticks. If you could maybe post a diagram or give me more info on how to do this, it would be much appreciated.
Controller trouble... Sleeping911 ZipZaps 0 06-24-2004 11:33 PM
Proportional Controller EMULATOR ph2t Bit Science 88 01-21-2004 04:12 PM
How do you hold your SE controller? rfnagel ZipZaps SE 6 10-06-2003 07:11 AM
Sucky Booster Controller aballen Bit Char-G Mods and Projects 3 09-28-2002 05:19 PM
