Old 10-16-2002, 04:12 AM
catman25 catman25 is offline
what the fastest motor the zip zaps can take from tiny rc?
wanna buy one but dont wanna get stuck with one i cant use like my 3.8 thanks
Old 10-16-2002, 10:22 AM
ax0n
the 23,500 RPM (NOS) Motor from the fast and furious kit is the fastest a ZZ can run with until you start tweaking it. it can use a 2.6 but it's really slow and you have to push it to get it moving.
Once you've done dual battery and other mods it should run with a 2.6 and probably the 3.0 and 3.8 if you work on it enough.
Old 10-16-2002, 10:45 AM
you got any pics of a better way of doing the dual batt. mod on a zip ..it it better to have two in the chasisis or one on the body ...
Old 10-16-2002, 10:55 AM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
that depends on if you want to turn and look good or look like frankinbit i put mine inside plenty of room at one time i had three in there
Old 10-16-2002, 11:01 AM
Mattydiah's Avatar
Mattydiah Mattydiah is offline
Attack of the Ugly Rocket
Depending on the battery size you may be able to get two batteries inside a Zip. Just WATCH THE STEERING WIRES!!! Another popular way to do it is to hack out the rear window and put it in there. That puts more weight towards the back for possible HOT HOT wheelie action.
As far as the mod itself is concerned, check my sig <shameless plug>
Check out the ZIPFAQ!!
I drive an Auldey, because it shouldnt cost you your first born for a 55MPH R/C car.
Zip Zap's for sale(or trade)...ALL complete! Cubicle For Sale/Trade 12 08-03-2003 12:12 AM
Fastest Modified Mini Rc Bit Char-g Zip Zaps aero Bit Char-G / MicroSizers 0 12-08-2002 12:16 PM
ZIP ZAPS Vs. Bit Char-g Short1mgb ZipZaps 0 11-03-2002 11:38 PM
Can Zip Zaps use other 27mhz controllers?? LCKKN]HT ZipZaps 10 10-30-2002 11:56 PM
