Old 09-25-2004, 02:19 AM
Bleek's Avatar
Bleek Bleek is offline
X-mod Innovator
How to win a Drag race (bet money on it too!)
Ok here what i figure, if u want to win a drag race, and I say drag race only because if u do this mod u don't have throttle control.
What you will need:
1 or 2 high voltage batteries that will fit under the xmods body
(if you dont want them to know what you are running other wise mount it on the outside if u wish)
Any sort of a transistor (3 pins) rated at a high voltage or to withstand the voltage batteries you are using
A soldering iron, solder, and wire is also needed
Procedure:
ok first find a spot to put your high voltage batteries
next, you can solder or connect 1 wire to the positive of the battery and to the 3rd pin of the transistor
then, take another piece of wire and solder it or attach it too the 1st pin of the transistor and to the positive of the xmod motor
next, take a nother piece of wire and attack or solder it too the negative terminal of the battery and solder it to the negative terminal of the xmod motor
then disconnect the mating clips from the xmod pcb to xmod motor seeing that u wont need the power form the board to the motor
next connect a wire to any part of the positive wire that went from the pcb to the psitive of the motor and the other end of that wire goes to the middle pin on the transistor.
now if anyone can follow my poor directions you should realize what happens.
Well heres what will happen, the transistor acts as a switch fir high voltage using a low voltage current to switch it on. The low voltage cominbg form the pcb will turn the transistor on when u hit the throttle thus allowing your high voltage battery to drain into your motor putting out extreme power and speed.
I recommend only doing one race as your motor will get hot very fast, but you will smoke whoever u race as long as you know what your doing.
Sorry for it being so long but i am typing it on the spot and thought of this about 5 mins ago and had to put it on the boards.
Peace
++ Project X-mod 2006 ++
X-mod EVO with CVT tranny!
hobby town to sponcer a MS race season!! MS_Modifier Bit Char-G / MicroSizers 31 08-31-2003 12:42 AM
Going 2 St. Loius 2 win your money Anybody want 2 race? zombiebaby Bit Char-G / MicroSizers 4 03-30-2003 06:54 PM
Drag Race Anyone? ripper7777777 Bit Char-G / MicroSizers 35 02-23-2003 02:47 AM
Drag Race Lights DavidDeLaurier Bit Char-G Mods and Projects 13 12-30-2002 03:32 PM
Drag race or road race? modifiedcelica Bit Char-G / MicroSizers 9 12-16-2002 03:51 PM
