Old 09-19-2004, 11:04 PM
djp42588 djp42588 is offline
Send a message via AIM to djp42588
Running the white differential in back
is is safe to run the white differential in the back with the four wheel drive intsalled (and the red bevel diff. in front)?
Old 09-20-2004, 03:57 PM
please
Red Supra = all traction
stg. 2 red motor
suspension, both wheel (im running ones painted white) tire, and body upgrades
speed kills: live long and drive a civic
1967 Camaro = all torque... no traction
md. rear springs and soft fronts side dual exhausts, all go no show and enough power to smoke your civic
Old 09-20-2004, 10:36 PM
Phred168 Phred168 is offline
Perfectly so.
Old 09-20-2004, 10:53 PM
thanks for the post... i have been driving it like this and i noticed a few things different
1. only the opposite wheel spins (in the opposite direction) instead of all 4 in the same direction.
2. less turning radius than the ball bearing red one
3. more torque.... drifting without drift kit.....!!!!!
4. more speed (i think less power is lost due to the slip in the ball bearing differential
i would reccomend this to anyone even if they dont have a broken ball differential (dont open it up... LOL put the 2 cups in opposite ends and spin them if they spin in the same direction its the ball if they spin in opposite directions it is the gear diff.
stg. 2 red motor
Old 09-20-2004, 11:06 PM
chrome01
You say less turning radiaus? About how much less in percent wise? A little, a lot? And finally do you have your front knuckles modified to have a larger turning radiaus?
Old 09-21-2004, 03:40 PM
jamgunner jamgunner is offline
Wannabe TinyRC Pro
Send a message via AIM to jamgunner
the red lsd has a tendancy to slip too much espeicialy on high traction surfaces hence the white diff is usualy better.
Old 09-22-2004, 05:42 PM
the turning radius is probably 80% that it is with the red differental but you can easily drift it with the more torque given with the non slipping diff.
stg. 2 red motor
Mounting Mini-Z bodies on Xmods neurokinetik XMODS Mods and Projects 18 12-28-2005 06:13 PM
The Ball Differential: LSD, USD, or LGD? Turnination Guy XMODS Parts and Hop-Ups 0 02-03-2005 01:29 AM
AWD question (need answer quick) 93Supra0wner XMODS Parts and Hop-Ups 7 12-30-2003 03:53 PM
how do you put the front axel back itnto the white knuckle Ghost of Akina Bit Char-G Mods and Projects 3 12-22-2002 09:55 PM
