Old 09-14-2004, 11:57 AM
cxjon cxjon is offline
Send a message via AIM to cxjon
my xmod pulls to the right bad
i tried to adjust the trim and nothing seems to help. also it turns left good and sharp but righ sucks. it seems the servo stops before its all the way. did anyone else have this problem?
Old 09-14-2004, 01:53 PM
obx22 obx22 is offline
Disassemble the front end of the car, remove the servo's bellcrank and reposition closer to the index center mark. Reassemble and you should require little trim adjustment.
Hope this helps,
warren
Old 09-15-2004, 12:29 PM
SupraWes SupraWes is offline
Send a message via AIM to SupraWes
Theres a full write up with pictures on the atomicmods site in the FAQ section on how to do this.
350Z X-Mod
Stage 2 motor, suspension & steering,
lights, all wheel drive, alloy wheel nuts,
CF Driveshaft, Wide Track Bearings, GPM front knuckles, GPM 0 toe steering plate, GPM front upper plate, RS wheel & tire package, GPM Rear upper plate, GPM rear cup joints and axles
Brushless Xmod and Jshwaa's EP for sale viperdout XMODS 7 12-20-2007 08:40 AM
Xmod Evo Truck HD Dogbone Mod CinnaBun XMODS Mods and Projects 0 02-03-2006 10:07 PM
Biggest Fastest REDLINE "BIG BLOCK V-12" ProPulsion Dragster XMOD MOTOR Ever! MicroRCracer XMODS Mods and Projects 25 01-26-2004 03:42 PM
Xmod Corvette Project Racer240 XMODS Mods and Projects 6 12-02-2003 08:57 AM
