Old 08-24-2004, 01:05 AM
sg219 sg219 is offline
Exclamation Nelly 1.2 Turbo invades USA and gets installed!!
Yes, kiddies Nelly 1.2 hit American Shores about a week ago and is now installed completely into a Brand Spankin' New Radio Shack Nissan 350z Chassis with a Honda Civic Body. I'll give all the specs at the end of the post.
Tools used...
Wire strippers
Wire cutters
Xacto knife
Nelly 1.2
Dual "AAA" holder
Xmod chassis
Small screw driver
Tweezers or something similar
Solder gun
Solder
Favorite refreshments
Sandwiches
And any other vices you may have or need to keep your patience and your hands steady.
The items to be installed. From left to right...1-Dual "AAA" holder, 1-Ph2t Nelly 1.2 Imported from Brucestralia, and 1-Test Motor (Later not used)
The guts of the Xmod chassis thats being used.
Tools, materials, work space, and stuff.
The PCB Board area.
The stock removed. How cute and tiny they look.
'K'eep. 'I't. 'S'imple. 'S'tupid.
Old 08-24-2004, 01:07 AM
Exclamation
At this point the steps are...
Break car down to the parts that you are going to be working with.
Think about how your going to go about the whole process, from beginning to the end. Play close attention to where you intend on mounting, placing, soldering, routing, any parts and/or wires.
Start work on the install.
I had great help in doing this. Bird from BitPimps and R7R did all the soldering and I asisisted the entire install. He loves to practice soldering and I just really don't have all the pantience in the world right now. So Bird got the practice on this install. Next one's all me.
THANKS BIRD FOR YOUR TIME!!! (The pay wasn't that bad either. )
OK, back to the install. Ph2t has a PDF that he made up to assist in doing the install, so I'm not going to go into specific here. Go read his Nelly Development Thread over at AusMicro. It'll have all the details you need for a successful install and info on the furthering development of Nelly into the BEST 1:28 scale MOD Board available!!
The Nelly 1.2 connected and tested.
Put in its place very carefully. Rear of chassis veiw.
Here you can see where the wires were routed.
Nelly 1.2 installed.
Old 08-24-2004, 01:08 AM
The Nelly 1.2 wires come up between the motor mount and the elctronics. The wires are ran on the bottom of the mount (rear/thin motor mount) and to the sides or corners of it, then up. I suggest replacing the motor mount once you have Nelly 1.2 installed and ready. This way you can have the wires routed proprely before putting the rear drive back on.
Yes, I know i said a Honda body at the beginning of this, but I like the one thats in the pic better!! It's whats eventually going to be on it anyway!!
Now there's is only one more thing to do!! TEST IT!! Thats the End of night one!! The next night we preformed the 6 cell modification on it.
This mod here is well documents, so there is NO need for me to explain this procedure!!
You can see here that the extra cell holder has been installed. It is directly wired to the loop and has a peice of velcro on the backside which attachs it to the top of the heat sink securely!!
Cut all the wires off the cell holder for this app. There is already enough wires around, so get rid of them. Solder the cell holder to the actual loop wires by useing the metal grommets on the end of it. By doing this the mod comes out looking much cleaner and precise.
Old 08-24-2004, 01:09 AM
The routing of the wires is a bit tricky, because you need enough room for Nelly 1.2, a Dual cell holder, velcro, and extra wires.
I routed Nelly to the front and down through the center of the CF front deck and up and out the front of it between the shocks and then toward the back. This leaves enough room to install the AWD later and positions the Nelly board in the right position to connect the motor wires. Plus its up under the hood/windsheild area of the car, leaving plenty of room for the extra cells.
Things to do while installing...
Learn from what your doing!!!! Is the most important thing.
This is what was learned through-out this install, both by, Bird and myself. He picked up different things and so did I, so if I leave anything ut Bird, Please post your experiance soon!!
Some of these will be gone back and performed on the car.
The Nelly 1.2 wires can be shortened by about 1 3/4 inches to 2 1/4 inches, depending on routeing and confidence in soldering and wire handling. We weren't sure how this procedure was going to go, so we stayed on the safe side. It when great, so shorten those Nelly wires for your install.
When soldering the rainbow wires to the PCB, do so, with the wires facing away from the switch area. This was a revalation after they were already soldered. We said let's try it this way and just never went back to change them. Also when soldering the power wires to the PCB, put them on at a slight angle so that they lead away from the chassis post when you put the PCB back in the chassis. Try it and see where they come out and the angle that works best.
Use a pinion pusher or a vise to put a pinion back on a motor!! i ruined 2 motors during this, all by trying to pound the damn pinion back on. I bent 2 armatures. The car now has an Escalation Motor from TOyEast installed in it with upgraded, thicker wires.
Use 18 gauge for all your wiring if possible. Rewire your motor leads, your battery wires, and anything else you feel comfortable doing. By doing this you get a sturdy system. I'm sure there might be a technical reason, but I'll leave that info up to the pros. (Ask Ph2t about it, i'm sure he has a reason and the knoweledge to elaborate on the topic of different gauges of wiring and they're functions.)
Take your time and have some extra time set aside for errors and adjustments.
Take pics and notes if your that type of record keeper.
Enjoy installing it!!
Here are the specs of the current car.
Stock Nissan 350z Chassis with front nose clip
Honda Civic Body (The 350z front clip raises the front end slightly and helps with the room needed to install everything. Slight, but enough.)
Nelly 1.2
5&6 Cells added
14 Bearings
6 Ray-O-Vac IC-3's
AWD diff
Escalation motor
Blue cone gear
11 tooth pinion
Black rims
Super Glued tires
Alloy Nylok wheel nuts
Soft Slicks
RC Butler Green CF front Deck (slightly modded to fit Nelly 1.2 thru the center hole.)
Used the wire from the cell holder and installed and replaced the wires on the Escalation motor.
1"x1" square of Velcro
Metal heat sink
Heat shink on the lower part of antenna. 1" or so, to protect from shorting receiver out.
Speed before 6 cell, just Nelly 1.2, using a regualr speed checker topped out at 31 km.
After 6 cell with Nelly 1.2 it topped out at 35 km.
It has an insane amount of torque, but now I need a motor that can fully take advantage of Nelly 1.2. A low wind motor. The Escalation motor just won't go any faster, its maxed out and so is the Stage 2 motor. A motor can only spin so fast, until you have to get a better built one. So to take full effect of the efficency of Nelly 1.2, I must find a BETTER motor now!!!
Thanks.....
Ph2t for developing, designing, constucting, and providing Nelly 1.2, the test motor, and online support. I purchased Nelly 1.2 from him. Please contact him for further ordering info.
Bird for his time, kitchen, and desire to get better at soldering. He helped and did alot of the work all the way to the final install. Great and clean job done, all the way around.
As for me, I supplied all the stuff and the testing grounds to install everything on. Research and Development supplies.
I will have some vid eventually. Soon I hope. The whole time, my 1:1 has been in the shop. So I haven't been able to hit the usually creepin' and filmin' spot. Soon.
I think I covered everything. If not I'll update the thread as it moves along.
Thanks for readin'!!!
Old 08-24-2004, 07:07 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Nice write-up sg219! FYI, we'll be stocking the 1.2 in the Shop shortly!
Old 08-24-2004, 07:57 AM
lancer11's Avatar
lancer11 lancer11 is offline
Pimpin'em Hoes
Send a message via AIM to lancer11 Send a message via Yahoo to lancer11
wat is a nelly 1.2
Red metal flake civic project tons of upgrades
Old 08-24-2004, 03:30 PM
newbitowner's Avatar
newbitowner newbitowner is offline
with the 11T RS motor?
My black Civic maxed out at 47km/h. check the sig.
black Civic, outdoor car...lowered..6 I-C3's..dipped 11T st2 motor..black chassis, rear upper deck & motor holders..metal bearings..alloy RL joint cup
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 08-24-2004, 06:03 PM
jamgunner jamgunner is offline
Wannabe TinyRC Pro
Send a message via AIM to jamgunner
wat is a nelly 1.2
word
is this like a replacment esc or what??
Old 08-24-2004, 10:04 PM
daracer daracer is offline
Anybody have a tutorial or link for the installation of this woah nelly turbo because the installation instructions over at ausmicro is actin weird and aint workin properly.Thanks
Old 08-24-2004, 10:12 PM
Thats the link to all the specifics.^^^^^^^^^^
I'm not going into the details of what it is, because I wanted to post a TUT on where and how to install it and the process involved in doing it.
Here is the short version of what it is.
An External Turbo=Ultra Fets=Ridiculous amounts of torque!!
Like I've said in every other thread I've posted about this Turbo. All the info is there if you read the freakin' post.
@the cat with 47 km/h Honda
Great job then. I would love to learn what you did to get it to do that. Post the pics and video of the process you did so we all can learn from it.
I'll say it again.
I don't dip my motors, it just seems weird to me, but to each their own. I just don't like the process right now. I might try it sometime in the future if the oppertunity presents itself.
I used new stock motors in my testing when installing Nelly 1.2. They were not broken in at all, straight out of the box/package.
Nelly is made for enhancement of a modded motor, not a stock. Nelly is made to give you more torque and better high end with a Modded motor.
I do not have a modded motor.
I will soon.
Old 08-24-2004, 10:27 PM
You setup must have torque uncomparable to my Civic.
I only have the mods in the sig, so I'm not going to show you how I did it. It's just 6 I-C3's, bearings, and a dipped 11T motor. I maxed at 45km/h without a 11T out of the box, not dipped.
...video...
http://www.rcpics.net/view_single.php?medid=36739
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
