Go Back   TinyRC.com > 1/24 and Smaller > Mini-X > Mini-X Gallery
Old 08-18-2004, 09:22 AM
xemet
Actual stage of my mini X prototype
Here is the current stage of my prototype:
Carbon Fiber Chassis and upper desk, six 2/3 A cells (1100 mA) longer wheelbase (110 mm) using a mini z 8T pinion on the front (shown in the picture). Alu slotcar rims with foam tires.
Next step: coil spring dampers (micro rs4 alluminium dampers). Steering linkage.
The body will be a lexan 1/24 nissan from truescaleproducts;
Old 08-18-2004, 09:23 AM
xemet
another pic
Old 08-18-2004, 09:24 AM
xemet
mini z pinion allows a longer wheelbase, necessary for 1/24 body
Old 08-18-2004, 09:25 AM
xemet
CF chassis
Old 08-20-2004, 05:40 AM
xemet
body
Old 08-20-2004, 04:28 PM
xemet
Steering linkage (handling is 200% better and faster!!) and front bumper done.
Old 08-21-2004, 03:54 AM
xemet
body paint
Old 08-23-2004, 06:14 AM
niceguyteddy niceguyteddy is offline
Dude, that looks sweet.
Any copies of that chasis available? or plans for it?
you have got Excellent results, good work that man.
Ted
Mini-x: Subaru
6 Cells
Bearings all round
vented bearing can
O/l tyres
Old 08-24-2004, 07:15 AM
xemet
Thank you Ted, no copies are available...it is an artigianal production! If you want plans I can give them to you, but you have to cut completely the original car to use this chassis.
Old 08-24-2004, 07:57 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Wow, amazing work xemet!
Old 09-03-2004, 04:09 AM
Twenty-Se7en's Avatar
Twenty-Se7en Twenty-Se7en is offline
looking great... one hell of an X
||| It does not matter if you win or lose. It only matters if I do. |||
Old 09-28-2004, 08:22 AM
ben1112 ben1112 is offline
It would be great to get rid of the long shaft motor.
Old 10-01-2004, 07:23 AM
helldriver's Avatar
helldriver helldriver is offline
Send a message via Yahoo to helldriver
I need that plans.
Can u mail me at wing@cbn.net.id
Thank u verymuch.
Old 10-15-2004, 10:35 AM
xemet
Talking
to ben1112
I have worked on a procedure to extract the axle from a common rotor and to insert in it the long axle for minix 4wd.
In this way I can virtually use every 130 size motor. Now I'm preparing a 4wd motor with PN 38T rotor, a bearing can, neo magnets and high quality carbon brushes.
I will post results...I'm waiting for the rotor bought on rckenon, I think it should arrive the next week.
See you soon!
Old 11-09-2004, 04:38 AM
xemet
this is my car now, with new 38T motor, new novak spy esc and new body.
xmod and mini x sawhit4 XMODS Mods and Projects 21 01-25-2004 02:03 PM
Links to Mini R/C Sites MicRoMaN Bit Char-G / MicroSizers 18 01-13-2003 02:55 PM
just about to order mini z or mini x but have a question tarnjit Mini-X 0 12-22-2002 10:01 AM
Mini Cooper Bit Char-g = A Lie Zakkorn Bit Char-G / MicroSizers 18 12-11-2002 06:05 PM
