Old 07-16-2004, 01:24 AM
lckyrocket lckyrocket is offline
Unhappy Help with Part!!!!
What is the black plastic part that connects the front left and right hub? Mine broke and i need to know what it is called. Also, do they make a metal substitute for it?
Thanks
My Xmod Skyline:
Stage Two Motors
Foam Tires (sometimes)
Mild/Wild bodykit (mixed)
Command Logic Lights
Awesome Graphics
6th cell in the works
Old 07-16-2004, 11:06 AM
rssjib rssjib is offline
Too many XMODS
I think you are referring to the front drive shaft retainer. It does not really connect the left and right wheels. It's main purpose is to keep the drive shaft from pushing forward. If you are running 2WD, you should just glue the driveshaft to the rear gear, and then you will not need that retainer. This way, the driveshaft stays put. Thanks.
RSSJIB
(2) Yellow Skyline GT-R: AWD, AtomicMods 180S motor, Li-Ion, CF driveshaft, suspension, bearings
(2) Black Skyline GT-R: AWD, Stage2 motor, Li-Ion, suspension, bearings
'04 Mustang: AWD, AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: stocker
(3) STi WRX: AWD, CF chassis, AtomicMods SS130, bearings, body kit, Li-Ions coming
Black RSX: AWD, Stage2 motor, suspension, bearings
Silver RSX: stocker
Red Supra: AWD, Stage2 motor, suspension, bearings
Silver Supra: body kit, Li-Ions soon
(2) 350Z: body kit, Li-Ions soon
NSX: body kit, Li-Ions soon
'65 Mustang: body kit, Li-Ions soon
_________________________
"rehab is for quitters"
Old 07-16-2004, 11:17 AM
Awesome, thanks alot man!
My Xmod Skyline:
Stage Two Motors
Awesome Graphics
Old 07-17-2004, 10:10 AM
duwain
then it will also be super hard to take the driveshaft out and if you ever want to change rear gears then your screwed.
Old 07-18-2004, 08:54 PM
jamiekulhanek jamiekulhanek is offline
Glue aint permanent man.....
one part just one ******* part kylecoston XMODS Parts and Hop-Ups 6 05-27-2004 03:34 PM
Part numbers for new Zips CaKid58 ZipZaps 6 10-03-2003 01:59 PM
custom chassis production has started ronak26 Bit Char-G / MicroSizers 45 02-24-2003 03:18 AM
