Old 07-14-2004, 04:00 PM
Maarbjerg Maarbjerg is offline
Question Dual cell info??
Hallo... I have read thinks about this dual cell mod, but I still haven't found out what is the good thinks about it, and what is the bad thinks?? Could somebody pls give me an answer... It would be a great help... Thanks
Ready... set... GO... :P
Old 07-16-2004, 07:13 PM
frizzen frizzen is offline
Tool User
Thinks or Things?
Dual cell: Run two batteries in the car.
Good things: More voltage, fairly easy to do, cheap speed, lets you take stock cars in races.
Bad things: More weight, needs special charger, changes CG and roll center.
Good entry level performance mod, pretty hard to mess up.
This has been far surpassed by switching to MosFETs instead of the normal SMT transistors. But you've either gotta know what you're doing, or send off a car and cash to somebody that does.
Old 07-17-2004, 06:59 AM
Thanks alot... *things* (ups)... MUST try that some day
The Layman's Dual Cell Mod (tm) actofgod Bit Science 207 02-16-2004 04:30 AM
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 08:42 PM
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 07:12 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 10:57 AM
Dual cell mod and discharge problem (cell reversal). kenny_dilger Bit Char-G / MicroSizers 1 12-17-2002 11:23 PM
