Old 10-14-2002, 07:01 PM
Gruder Gruder is offline
Send a message via AIM to Gruder Send a message via Yahoo to Gruder
(axOn) Food for thought
Guys I have an idea I will run buy and see if anyone is on the same page as me. Has anyone thought of putting in a second battery in parallel with the positive side tied to the collector side of a heavy duty transistor. The emitter side of the transistor tied to the positive input wire of the motor. Unhooking the positive side of the motor wire from the PC board and soldering a new wire form the positive out put on the PC board to the base of the transistor. You do not have to do any mods to the charging system and when you start to go forward this will bias the transistor and supplying the motor with 1.2v and all the current that the transistor will allow to pass through it. Please tell me what you think of this Idea. Like I said it is just a thought.
Gruder
Old 10-15-2002, 09:34 PM
ax0n
I JUST SAW THIS...
Sorry for not replying.
I'm not sure how well this will work, but it sounds like it would. You could maybe not do a dual batt setup and run this straight from the first battery.
Old 10-15-2002, 11:17 PM
Bus Driver!
You should double your possible current to the motor.
food for thought... arch2b XMODS 12 01-01-2004 10:55 PM
Favorite food viperkilla Miscellaneous Discussion 25 05-19-2003 05:30 PM
