Old 07-06-2004, 07:37 PM
Bleek's Avatar
Bleek Bleek is offline
X-mod Innovator
AA mod
has anyone tried to change form AAA to Double AA because when i look at AAA ic-3's there 800 mah which is good but when i look at AA ic-3's they are 2000 mah which is great! i would change out the battery holders for AA in a heartbeat but can the cars stock electronics handle it? and if there is a thread on this plz direct me beczuase i tried to search for " xmod AA mod but ofcourse we cant search for words less than 3 letters. so anyone out there plz help and advise.
- Bleek
++ Project X-mod 2006 ++
X-mod EVO with CVT tranny!
Old 07-06-2004, 11:05 PM
JDM-R34 JDM-R34 is offline
Send a message via AIM to JDM-R34
From what I've heard about converting AAA to AA it's just a waste. AA's wouldn't make Your car any faster, they would just make it slower, seeing that AA's way more than AAA's. If You want more power going into Your car Use AAA IC-3's and do a 6 or 7 cell mod, either mod will make Your car a lot faster, adding a 7th cell might not work, (not enough room under the body) so just go with 6 cells and use IC-3's instead of normal Batts. You could always go the lithium way, even lighter and faster.
Old 07-07-2004, 12:33 AM
Bleek's Avatar
X-mod Innovator
unfortunatle everytime i try even 5th cell i fry my reciever any way of avoiding that???? and i use ic'3
Old 07-07-2004, 12:44 AM
allahsone allahsone is offline
i used (8) 9.6 volts of rechargable AA's 2300mah adfter a lil while burnt my fets. im sure itwill do better with a fet stack but you still have to think about the weight ratio. i might even sell my xmod
Old 07-07-2004, 02:04 AM
Bleek's Avatar
X-mod Innovator
thanx for the input
AWD with Resistor Mod for steering cool_cars XMODS Mods and Projects 20 12-04-2004 03:10 AM
Best Mod Contest (UNOFFICIAL) midget_man1387 Bit Char-G Mods and Projects 56 03-17-2003 10:38 PM
