Old 06-29-2004, 01:09 AM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
chassis extention
I have an Oldnslowmobile 442 body that i would like to put on my XMOD the only problem is i have to extend the chassis about 25mm to fit the wheelbase of the new body. I know somebody here was talking about making some so who ever you were i need a step by step to extending a chassis.
racing on pavement is for wussies.
Old 07-13-2004, 11:22 PM
Shelby_HEMI's Avatar
Shelby_HEMI Shelby_HEMI is offline
Go me...
I have a '73 Trans-Am I want to do the same thing to.
Old 07-14-2004, 01:58 AM
civic freak's Avatar
civic freak civic freak is offline
Tiny RC Guru
i am not the person you are looking for but i am working on a very simple extension. its basically 3 bars between the main chassis and the black gearbox thingy( the black thing that holds the differential, rear suspension components etc.) one bar for each side and one bar that goes between the other two bars so that it will have as little movement as possilble.but the thing i have not gotten to work yet is ground clearence.if i find a thin enough material it is to weak and sags if it is strong enough it will be to thick and drag. i will attach a crude picture:
Old 07-18-2004, 03:01 AM
Bruce Schaefer Bruce Schaefer is offline
Chassis extension Correction
I have done two chassis extensions adding 50mm by carefully cutting two chassis bodies to the correct individual lengths and superglueing them together with small pvc foam braces on the inside overlapping the join. I wanted to put 1/32 Kenworth Semi Tractor bodies on the xmod so I lengthened the chassis and then added a second shortened , non-powered axle at the back for the dual axle look. The chassis is holding together well but you have to be careful in the cutting and joining/glueing. I have attached a scan of how I would do it to add approx 25mm length.
Old 08-05-2004, 02:58 AM
hotrod29728's Avatar
Can you get pictures of that Kenworth? I was thinking about a Peterbilt body I have lieing around here...I didnt want to chop it all up and i even have the dual rims and everything... Could you give me pix so I can get my body mounted....
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Micro-T Carbon Fiber Chassis DAMZer Micro-T Parts and Hop-Ups 14 05-20-2010 07:57 AM
Carbon Fiber Chassis WillS Mini-X 22 08-13-2003 08:17 PM
custom chassis production has started ronak26 Bit Char-G / MicroSizers 45 02-24-2003 04:18 AM
Stock chassis warp Mr Freeze Bit Char-G / MicroSizers 0 12-06-2002 12:35 AM
Chassis Extention Mod nivirt Bit Char-G Mods and Projects 15 11-25-2002 05:50 PM
