Old 06-17-2004, 07:38 PM
theone&only.... theone&only.... is offline
dumb Q
ok, i know this is off topic for this forum but i am very confused. when i go to http://www.mikromodellbau.de/eindex.html
all the prices are in Euros. but when i go to unit converter. i type in what it says for price. lets say 30,00. thats what it says so i typ that into the converter and press convert andit comes up with $36,00 USD. so what my Q is that when i do the convert do i have to include all the zeros and stuff after the , or is the , a . in germany.
thanks,
Bryan
Old 06-17-2004, 07:52 PM
also for my unimog that i am going to build i found the rear axle i want to buy. yes buy. i dont want to make my own. its a swing axle. it say 1:19 ratio, thena 1:228 final ration. becuase it a swing axle it has the out shaft then off the output is a worm gear that powers the rear axle. so i found a front axle with the ration of 1:12. so i went back to the other rear gear box and did some math. the first ratio on the rear gear box is 1:19. and the second is 1:228. so i took 228 and devided it by 19 and got 12. so i believe that would make the rear axle spin at 1:12. the same as the front. pleae anyone with knowlage of this would you help me.
thanks,
Bryan
Old 11-10-2004, 03:17 PM
frizzen frizzen is offline
Tool User
Europe uses the , as a . for numbers So, you're right that "30,00" is actually "30.00"
It's just one of their silly quirks, kinda like spelling color as colour, or using Celcius for temps.
I believe you've got it a bit off on your gear ratios. I assume you've got: motor pinion - reduction box - then drive axles?
You actually can't figure your Final drive ratio until you've got all of your gears picked. So where did you come up with the 228:1? I agree that 12 x 19 = 228 But, your front will be running faster than rear no matter what, until you add another gearset or fix it.
Front drive ratio: 12:1
Rear drive ratio: 19:1
So, do you want to try for speed (12:1) or torque (19:1)? Either way, you've got to bring your axles to the same ratio so they can use the output shaft from your gear reduction. The *easy way* is to swap gears so your running an identical gearing, or you can go the hard way figure it out and add more gears so you get more friction.
I *think* you need a stepdown of like 1.583 between your front and the output from your reduction. (I'm probably wrong as I'm being stupid at the moment.)
But if I'm remembering correctly, you have to divide the ratios to figure out the difference, then the answer tells you what ratio you need to compensate. 19 / 12 = 1.5833 repeating. so I *think* you'd need like a 1.583:1 ratio, but it'll still be a little tiny bit off so I'd just replace the worm gears so you're running front and rear at same.
This might be a dumb question...... Bleek XMODS 6 01-31-2004 05:46 PM
some radio shack people are dumb census007 XMODS 3 01-18-2004 11:01 AM
dumb mistake...can u help? stealthboy XMODS Mods and Projects 10 12-30-2003 02:37 PM
Dumb Overland Question(s) Distress Mini-Z - Mini-ZRacer.com 1 09-01-2003 11:04 AM
dumb question rt450 Bit Char-G / MicroSizers 6 03-31-2003 05:46 AM
