Old 05-21-2004, 10:45 PM
bluemonster bluemonster is offline
Need some direction for custom 1/24 crawler
I am starting with a 1/24 scale model body, and working from there. I have wanted to do this for a long time.
I plan on building a brass tube frame, using solid axles and a 540 motor for ultimate torque.
The chassis will not be a problem, I have made them before. I an make any parts that I an get work, I just need some help seleting parts.
I looked at the TLT-1 today, and am very impressed with the solid axles it uses, very nice, and would need very little modding to make them work. Are there any other solid axles out there that could be used?
What about tires and wheels? I want to keep it as scale as possible, so I am thinking aluminum wheels and the nie meaty tires that are out for the Mini-T.
Any suggestions?
Old 05-22-2004, 01:44 AM
Xmodracer1 Xmodracer1 is offline
You could Try Xmod Aluminuim Cup Joints at
[url]http://www.xmodspeed.com/product_susp.htm
Click for details Aluminum Cup Joints
Aluminum cup joints from Custom RC Specialties. Aluminum replacement axle cups for XMODS. CNC machined to better than original specifications. 40% lighter than original parts.
$10.00 Right Rear
$8.00 Left Rear
$8.00 Right Front
$10.00 Left Front
Aluminum Lug Nutz at http://www.xmodspeed.com/product_app.htm
$3.95 Set of 4 Lug Nutz
these Lug Nutz are made to last for going extremely fast, with out messing them up.
http://www.xmodrc.com/wheels.html
Xmod wheel upgrade kit $10.00
Website: http://www.radioshack.com/product.as...5Fid=60%2D8508
Store: radoshack
If your rc wont work on 4 wheel drive
buy the Xmod 4 wheel drive upgrade
Website: http://www.radioshack.com/product.as...Fid=60%2D8506.
Store: radioshack
I not familiar at giving information on parts that go to different things, I only had a Xmod that was 1:24 Scale.
The Mini T tires should fit on the Xmod wheel if it is a 1:24 Scale.
How do you have enogh room to fit a 540 motor on a size 1:24?
My Xmod can only fit upto a 180 motor.
More About Xmods
http://www.rcxmod.com
http://www.atomicmods.com
http://www.xmodworld.com
http://www.xmodconcepts.com.
http://www.vxb.com
http://www.suzies-skunkworks.com
Old 05-22-2004, 05:17 AM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
The TLT axles are to big for 1/24 scale they will look way to big but the VENOM mini giant is what you will need it is 1/20 scale and is much smaller than the TLT, more true to scale.
It has solid axles but only the front axle steers so if you want 4WS you would need two front axles.It has a very compact center gearbox.
The mini giant comes ready to run for around $99.95-$129.95 depending on where you buy it.There is a bearing kit that can be purchased for it.
I plan on putting a 1/25 scale AMT bigfoot monster truck body on mine and it will fit perfectly as far as wheelbase goes.
The mini giant would look good with a tube frame and nicely finished plastic model body mounted on it.
Old 05-22-2004, 05:51 PM
Thanks a lot, I have a lot more info to research now. I am assumming that the Venom parts will work best, but I will completely check out the XMODS links as well, you never know what you may find!
A Crawler zzultimate ZipZaps Monster Truck 10 08-06-2007 05:57 PM
Highly modded crawler Hildy ZipZaps Monster Truck 3 07-11-2006 06:04 PM
1/24 Rock Crawler bluemonster TTTT 4 01-07-2005 11:27 PM
1/24 Scale Cars? jfoxh ABC DTM SP 4 03-28-2004 08:52 AM
WTB: cheap 1/24 scale (complete) JTM For Sale/Trade 2 02-25-2003 06:12 PM
