Old 05-21-2004, 05:25 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
heres the way i roll
1: awd sucks
2: awd makes you slow
3: awd makes turning radius crappy
4: why hadnt i replaced the stock antenna before today.
5: proper antenna length is 13.5in
6: possi rear kicks ass.
Old 05-23-2004, 05:58 AM
Shiporu's Avatar
Shiporu Shiporu is offline
I make great sandwiches
Send a message via AIM to Shiporu Send a message via Yahoo to Shiporu
same here man. hey hogjowls, have you tried using the bearings with your AWD? when turning with the AWD, try letting off the throttle a bit then punch it. i find this to helps turning a ;ittle tighter with the AWD. as far as slow goes, do you mean in top speed or acceleration? with AWD, you are bound to lose top speed, but your acceleration should be better, cause 4 wheels are doing the work.
-shiporu
My Xmod:
now has Tiny Rc parts and schools everyone here!!!
Old 05-23-2004, 06:48 PM
SHIFT_DRIFT's Avatar
5Zigen
a lower center of gravity helps.
i have laid down batt. packs.
Try And Sleep Now.
DRIFT my ANTI-rice
Old 05-24-2004, 05:45 AM
Shiporu's Avatar
bird,
the same thing happened to me when i racing a friend at night. let's see...oh i lost the stock tire, and a soft slick. we looked for hours, but could not find the tires...oh well
hogjowlz,
yoo could also shift the batteries forward to give more weight distribution to the front. I went out today with my AWD civic, and i beat my friend using the blue 11 tooth motor. both in accel and top speed. I really suggest using the metal bearings with the AWD. BUT I use tinyrc.com parts, I really recommend it!!
-shiporu
My Xmod:
Old 05-28-2004, 02:12 PM
viperdout's Avatar
It's Really Fast!
I lost a tire in broad daylight! I happen to like AWD, because I seem to get a better grip inside, but outside, I think RWD has an advantage.
Project Bad Brushless:
Just say no to giant sigs.
Old 05-28-2004, 03:40 PM
viperdout's Avatar
It's Really Fast!
Maybe this kid put it on a gold chain. Now that would be medium pimpin'!
Old 05-28-2004, 09:05 PM
Shiporu's Avatar
since i have imcomplete sets of tires, i will have to do that just for the heck of it. "what that around your neck"? they will ask, i will say, "xmods tires"....
-shiporu
My Xmod:
Old 06-04-2004, 10:24 AM
ax0n
I lost a stock tire the first week I had my xmods.
Anyhow, all better with the tire upgrade kit. I've since lost one more, and believe it or not, I actually totally wore out two soft slicks after massive amounts of runtime at a skate park (smooth un-finished concrete rawks) and tennis courts (smooth fine asphalt laid on top of concrete rawks even more!)
Anyhow, I took my Skyline's stock wheels and super glued a set of fresh slicks to them. Now it handles better, the tires don't fly off or come out of alignment and rub on things, and there's no phantom wheel spin (where the tire grips the surface but slips on the wheel)
Other than that, AWD is useless unless you have CRAPLOADS of torque (such as running a FET stack and upgraded motor and power systems) or you're racing on a really slick surface, such as ice (which is fun as hell with AWD) or hardwood floors that are not clean. In those instances AWD helps you handle better and accellerate faster. If you're not losing traction with RWD, then you don't need AWD.
If you're losing traction with RWD, try different tires and suspension setups before trying AWD. The AWD kit is worth it for the ball (limited slip) differential alone though, which I use on the back.
My current setup is fast as hell with handling to match for bone stock electronics and no "unethical" modifications whatsoever (only 4 batteries and official XMODS motors):
Stg 2 Drag (blue) Motor/gears
Stock wheels with soft slicks glued to them on all four corners
4 NiMH AAA's (Rayovac, not the 15 minute charge ones)
Ball Diff in back
Ball bearings
Yellow (medium) suspension in front, Blue (hard) suspension in back
Stock steering tie rod
I dremeled out some "extra" plastic on the body, like the parts under the hood, and thinned the plastic on some of the thicker areas of the body. I'm contemplating puttying over the spoiler holes and going wingless to save a few more grams
Also, I have pretty much every available part for the XMODS that RS sells aside from the different gearing for stage 1 motors and foam tires. Talk about a waste! I had all this stuff on my car and I'm like WHAT THE EFF IT'S AS SLOW AS IT WAS WHEN I BOUGHT IT!!!
Command Logic Lights, suck battery power and weigh 7 grams or so. OUT!
Body Kit parts weigh something like 12 grams over the stock parts they replace. Back to stock (I left the cool steering wheel alone though!)
AWD kit adds 6 grams or so, and increases drivetrain parasitic power loss without any speed benefit on most surfaces. Un-Installed!
If I were going to do it all over again, I would have only gotten the following:
1) Starter Kit
2) AWD Ball diff for $3 or so from atomicmods.com
3) Bearings
4) Wheel upgrade and Tire upgrade (and glue various tire types to the wheels)
5) Stage 2 Motors
6) Suspension
That's it. Although, I'm eventually going to be running 8.4V with a FET stack and upgraded motor, in which case I will have a need for the AWD kit again.
Old 06-04-2004, 01:40 PM
viperdout's Avatar
It's Really Fast!
Not true. AWD is sweet. I put it into my Skyline when all it had was a Stage 2 motor, and the grip was just a million times better.
Roll Bar For Chevy Silverado pain899 ZipZaps SE 2 06-28-2006 01:28 PM
Roll Bar For Chevy Silverado pain899 ZipZaps Monster Truck 1 06-27-2006 12:17 PM
custom roll cage Kevmiester XMODS Mods and Projects 3 08-05-2004 09:08 PM
roll cage pistonhead678 Bit Char-G Mods and Projects 12 04-22-2003 11:06 PM
Roll Bar's !!!! CopeCowboy1 Bit Char-G / MicroSizers 7 11-06-2002 08:31 PM
