Old 04-24-2004, 11:02 PM
impression_xmod's Avatar
impression_xmod impression_xmod is offline
Send a message via AIM to impression_xmod
question about rear deck
you know that little rasied peice that the antenna is mounted on? well what if that was just flush with the deck? like just screwed into the deck... not raised. would it be okay? any problems with doing this? there is a reason i am asking. thanks...
carbon fiber decks, carbon fiber driveshafts, carbon fiber and aluminum lips, aluminum wheels nuts, replacement stock parts and cheap xmods starter kits.
LAUNCHING MAY 7TH
Old 04-24-2004, 11:23 PM
Draconious Draconious is offline
Send a message via AIM to Draconious
as long as that yellow piece aroudn the motor stays there, to keep antenna from touching motor.. it would b ok I guess... it will short out if the antenna motor ever touch, even if car is off...
would be just as bad if it hit that battery terminal next to it too, and that looks easy to do... maybe insolate it with liquid elect tape ?
Old 04-25-2004, 12:33 AM
what isolate the battery terminals or the antenna? or both?
LAUNCHING MAY 7TH
Old 04-25-2004, 01:23 AM
SHIFT_DRIFT's Avatar
5Zigen
isolate the antenna.
or both if u are safe.
Try And Sleep Now.
DRIFT my ANTI-rice
Old 04-25-2004, 01:38 AM
cool thanks... this thread was in regards to mass production of the carbon fiber rear decks. thanks.
LAUNCHING MAY 7TH
Rear suspension on a bit? chelboed Bit Char-G Mods and Projects 28 04-13-2003 09:51 AM
Solved KIT rear issue...... DarkTari Bit Char-G / MicroSizers 0 02-10-2003 10:48 AM
KIT rear axles...question MTL Bit Char-G Parts and Hop-Ups 10 02-09-2003 11:02 PM
whoa, Taiyo rear is removable, meaning: CUSTOM T BAR REAR SUPSENSION MOD TIME!!! MTL Auldey (All) 6 12-30-2002 07:53 PM
