Old 04-18-2004, 11:15 PM
bdnunchaku
Question for ION and all: SP Frequency 40abc compatibility
ION specified in a previous post that the super perfection 40Bmhz will control a 49mhz Microsizer. This is all the info I could find in this forum. What about 40A and 40C?
Because Toyeast is selling only 27abc and 40abc frequency's, I am hoping that they represent the following:
27a = 27mhz
27b = 35mhz
27c = 40mhz
40a = 45mhz
40b = 49mhz
40c = 57mhz
Can anyone confirm this? Or does anyone by chance know which one of the lettered frequency's won't interfere with 27mhz (motorworks), 40mhz (old lxx booster) and 49mhz (microsizer)?
Old 04-19-2004, 04:51 AM
Draconious Draconious is offline
Send a message via AIM to Draconious
They are cheap TX/RX devices... they will likely interfere with each other regardless of frequency its common for 27mhz Bit Char G to interfere with the 49... if the situation is right.. close enough, etc...
price thats paid for cheapness... the clones are even worse...
The closer the number of the mhz is the more likely it will interfere with another car, but it more than likely will have dificulty controlling it...
27 = 27... I doubt a 27 numbered car would be on a 40mhz channel.... the abc is probly just colors of bodies or something...
Old 04-19-2004, 06:17 PM
bdnunchaku
No, the a,b or c indicates different frequency channels.
Old 04-19-2004, 06:19 PM
bdnunchaku
Looking for tech info, not a review.
Old 04-21-2004, 05:18 AM
TeamBonzer TeamBonzer is offline
Re: Question for ION and all: SP Frequency 40abc compatibility
27a = 27mhz
27b = 35mhz
27c = 40mhz
40a = 45mhz
40b = 49mhz
40c = 57mhz
Yes I can confirm those frequencies. If you buy the toyeast mini collection you will find the same frequency pattern on the 27 (i,ii,iii,iv,v,vi) mhz cars.
Cheers
TB
wwwbonzerracing.com - Scream for More. Race for real - not in slots!
Old 04-26-2004, 08:53 PM
boho's Avatar
boho boho is offline
Camera springs
Yes, I'll confirm the fact that they are on different freqs than they say. Don't know wich ones though.
You could tune the potentiometer if you are getting interference from another controller. If it's alot of interference, then I wouldn't bother, but if it's only a little then it might work.
Basically, the whole pots mod came about to increase range. But you could also do the reverse to take it out of tune with a different controller. Incidently this may increase your range as well.
It works like so; Look at the bottum of the car's pcb. There is a white cylender, plastic-like piece that sticks up. This is the potentiometer. If there is any goo on it, then carefully scrape it away with something. You'll probably need a friend for this next part. Basically you'll see a screw inside it after you take all the goo off. This needs to be adjusted (turn it clockwise or counterclockwise)with something NONMETALIC. Metal will interfere with the process and give you incorrect results. The best way to do the pots mod is to have one friend stand as far away from the car as he can and still get a signal. Now adjust the pots in very small rotations. The range should increase because you are getting it more in tune with that controller. On the flip side, this can be used to take it out of tune with another controller. Keep in mind that the car may already be tuned the best it can be. Most aren't though.
Old 04-26-2004, 08:58 PM
boho's Avatar
Camera springs
I know this may have been a little more info than you wanted. I know the 27a is on the same freqs as the tomy 2-speed 27mhz.
Old 05-15-2004, 06:01 PM
bdnunchaku
27a = 27mhz
27b = 35mhz
27c = 40mhz
40a = 45mhz
40b = 49mhz
40c = 57mhz
Confirmed to be correct for the lxx super perfection. Also on a side note, in the bit faq page, they have the frequency's listed backwards for the old lxx (it should be this way: 01=27mhx, 02=35mhz, 03=45mhz and 04=57mhz).
Old 05-17-2004, 04:54 AM
Matic Matic is offline
No it is not. It is a coil.
Old 05-19-2004, 04:37 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
i love the sea of misinformation on this site.
and no they aint lying when they say 27abc and 40abc.
draconius is correct about similar frequencies crossing from time to time. but he is exagerating how common it is.
normally the lower freq will be the higher one's bitch.
i believe the superbits use a different chip and they use a different modulation so i believe this whole thread is based on LIES.
thank you drive thru
Old 05-21-2004, 08:41 AM
boho's Avatar
Camera springs
It's a potentiometer. If you look close, you'll notice a little more than just a "copper coil". Go ahead, take a look. There is a small peice of lead, some other stuff, etc, etc....
This pot is used to pick up the signal. Certain amounts of wraps and the position of the lead dictate wich freq it can grab a hold of.
I'm really getting tired of this place.
Old 05-21-2004, 09:16 AM
I will check, but I`m preety sure that is a coil with adjustable ferite core which is common in rx and tx. Micro-Amps answer this plz....
Old 05-21-2004, 12:43 PM
hogjowlz's Avatar
hey boho: check out http://bitpimps.lixlink.com
any others we probably dont like you so dont check that ste out
