Old 04-08-2004, 05:04 PM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
Unhappy Help!
i was running my supra in our shop where i always do and was doing high speed drifts i was full throttle down a long straight and went to turn into my dirft and a rock stuck under the front of my car so i lost steering control and still at full throttle ran head on into a very large air tank i then made the run back to the start of the straight and punched it it was only the third run including the crash and it was acting like i had made the 10 to 15 runs i normaly get out of a set of batteries. i want to know if it may be serious i was on fresh batts one of the batts did pop off of the contact but i put it back in correctly and it didnt make a difference. im running rayovac nimh rechargeables that are on their 7th or 8th charge
racing on pavement is for wussies.
Old 04-08-2004, 06:25 PM
striker289's Avatar
striker289 striker289 is offline
Sp33D D3m0n
Send a message via AIM to striker289 Send a message via Yahoo to striker289
check ur wires maybe u have a lose one
Getting back into the hobbie w00t!
Old 04-08-2004, 07:25 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
i dont think a loose wire would have done it. try recharging them and see if maybe the shock did something.
NEVER UNDERESTIMATE THE POWER
Old 04-08-2004, 08:28 PM
striker289's Avatar
Sp33D D3m0n
if a wire is partly broken off it will be weak beacuse of less contact
Old 04-18-2004, 05:08 PM
viperdout's Avatar
It's Really Fast!
What he said.
Project Bad Brushless:
Just say no to giant sigs.
Old 04-18-2004, 05:32 PM
aperson's Avatar
so if it was hanging by a single strand and a lot of amps were being pulled through it the wire would break just like in a fuse right?
Old 04-19-2004, 04:48 PM
Joey's Avatar
Joey Joey is offline
That could be so, but a wire wouldn't have to be hanging by a lone strand to have a weak electrical connection. The mechanical connectivity could be just fine, but even if some snapped wires are touching, if there are enough breaks, you'll lose a lot of power in the exchange. Still more power may be taking more time to get where it's going, possibly characterized by sudden jumps and drops in current.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
