Old 04-06-2004, 12:03 PM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
better antenna
i was bored last night and decided to make a decent antenna for my car to stop the stuttering. i had an old clock radio laying around with a soft wire anntena and "borrowed" the anntena then i swiped the antenna tube from my broken buggy and trimmed it to about 8 inches and made the wire about 9 inches. Then i stripped the wire on the first half inch on the bottom and made a loop to screw to the car and left the rest of the extra hanging out of the top of the tube to make the tube work i had to enlarge the hole in the body a little but now i can drive more than 6 feet without it stuttering i can dirve about 25 feet
racing on pavement is for wussies.
Old 04-06-2004, 12:42 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
did you tune it? i made my new antenna 3X the normal antenna size. i have yet to test it though. im working on waterproofing right now.
NEVER UNDERESTIMATE THE POWER
Old 04-06-2004, 02:10 PM
micro kid's Avatar
i went out and measured off the distance till it stuttered and i was way off in my estimate it was acctualy just over 40ft
Old 04-08-2004, 01:36 AM
micro kid's Avatar
the mount
i made the mount for my new antenna. first file the notch in the back body mount a little bigger for clearance then get a piece of thin plastic and cut it long enough to wrap around the original antenna mount and the new antenna at the same time then poke a hole through and put a small screw in so that it will hold the plastic around the mount and antenna tightly then put the part of the wire that was stripped down the notch in the back of the antenna mount and put theantenna it self up against the notch tighten the screw and make sure the antenna is snug. thats it.
Old 04-08-2004, 08:35 PM
aperson's Avatar
how about some pics? but did you tune it? as in measure the antenna and make the new antenna 1X, 2X, 3X, etc.? not the actual range.
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 08:09 AM
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 10:38 PM
Antenna Support System got BITS? Bit Char-G / MicroSizers 7 03-27-2003 12:25 PM
stock antenna lenght big-key Bit Char-G / MicroSizers 3 02-23-2003 12:39 PM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 12:13 PM
