Go Back   TinyRC.com > Miscellaneous Discussion
Old 03-27-2004, 01:44 AM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
E-Maxx bashing
went out and bashed the E today with one goal, break the thing . well i acomplished breaking it but not enough to warent any new parts i had a ramp set up on the side of a planter that was about 4'5 tall i used a piece of expanded steel as the ramp and on a practice/test run i juiced it to see how the ramp would act and the truck launched to the left hooking a post with the right rear tire causing the shock caps to blow on that corner then it fell upside down about 5 feet to a concrete side walk.no serious damage but now i need shock oil anyone know what comes stock in the E-Maxx?
racing on pavement is for wussies.
Old 04-29-2004, 09:47 AM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
i dont know but you should get the highest weight oil you can find because of the 9+ pounds of plastic terror
Old 04-29-2004, 10:36 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
Your shock caps are going to keep popping off until you upgrade them. I would reccomend big bores although they can get expensive. Fow my rusty a set of 4 big bores was $60. That put's the price at over $100 dollars for the 8 shocks on an emaxx. Did you really want to break something that expensive?
