Old 03-22-2004, 11:57 PM
Itan Itan is offline
Send a message via ICQ to Itan Send a message via AIM to Itan
deataching gears
I took apart a broken camera today and ran across some really small plastic gears but i did run across these little gears that you see below but i dont know how to get them off any sugestions?
Old 03-23-2004, 12:03 AM
wow thats a bad pic let me download drivers for my digi cam and take a new one
Old 03-23-2004, 01:02 AM
this should be better
Old 03-24-2004, 07:45 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
the easiest way of removing the gear on that metal shaft is by using a piece of wood... drill a hole which is the same size as the shaft but not bigger than the gear you are to remove... slid in the shaft into the hole then tap it lightly with a hammer or you could use a visegrip on the other side to pull that shaft off the gear .. be carefull
hehehe
Old 03-24-2004, 04:29 PM
thanks killer
Pinon gears. dje7447 Bit Char-G / MicroSizers 7 10-09-2003 03:52 PM
Tips for quieting gears NoPropMan Bit Char-G / MicroSizers 14 03-27-2003 11:59 PM
WTB/T for gears big-key For Sale/Trade 0 03-06-2003 12:19 PM
clone gears vs bit gears ? Mike the Great Bit Char-G Parts and Hop-Ups 10 01-19-2003 01:05 AM
loud gears?? streetrage Bit Char-G / MicroSizers 6 12-16-2002 11:11 AM
