Old 03-20-2004, 11:49 AM
N2O N2O is offline
Im With Stupid -->
Thumbs up Parts-galore + Easy-mods
O.k people,i got really bored so i decided to go through all my old stuff to find parts for moding my car..i came across an old tech deck ramp and other ramps...if you have ever had a tech deck ramp or still have one i'd advise you to listen to this..
(NOTE THIS TIME THIS IS 100% OF MY OWN RESEARCH..NOT PLAGURISM!!!)
benefits :
-The best muffler you can get! (plus you can shape it!)
-body kit plastics
-plastics for allsorts of mods (mainly thick plastic mods)
-Nitrous tank replica (N20)
and maybe more...
non-benefits :
-NO MORE TECH DECK RAMP
O.k step 1
1.Take your ramp and where the grind rail is on the two steps..gently pull the two off and keep them...
2.At either end of the rails should be two little loose pieces of plastic,take these off and keep them.
3.The two steps should have gaps where the rails were.so where the gaps are get a, e.g screw driver and lift the tops of the steps off through the gap...Leaving a board of plastic which you keep..
4.o.k with the grind rail you pulled off in step 1,you can now cut and shape it into the coolest muffler ive ever seen,(its easy and it looks like the real thing!)
5.with the loose pieces of plastic you removed from step 2 take them and paint them (optional,i prefer black or silver) ,and then either paint or add a decal on saying n2o or nos,What ever you like.
6.that will make to cans of nitrous which you can place anywhere on or in your car....
7.with the two boards of plastic you removed in step 3,you can now cut,shape,bend or do ANYTHING with this to make E.G body kits,spare plastic parts,spoilers....THE CHOICE IS ENDLESS..
O.k hopefully that has helped you,if not its probably my fault,because im not exactly a great helper on forums..
anyway hope its helped...Sure helped me so cya's l8er
Tinyrc.com Rulez!
Old 03-20-2004, 12:01 PM
N2O N2O is offline
Im With Stupid -->
ok heres the pick for step 1.
Tinyrc.com Rulez!
Old 03-20-2004, 12:02 PM
N2O N2O is offline
Im With Stupid -->
and step 2...
Tinyrc.com Rulez!
Old 03-20-2004, 12:04 PM
N2O N2O is offline
Im With Stupid -->
and finally step 3...
Tinyrc.com Rulez!
N2O N2O is offline
Im With Stupid -->
sorry for the bad images and bad info..please reply....
Tinyrc.com Rulez!
Old 03-22-2004, 07:18 AM
N2O N2O is offline
Im With Stupid -->
WHY WONT ANY1 REPLY?.....
Tinyrc.com Rulez!
Old 03-22-2004, 03:01 PM
wekilledbambi03 wekilledbambi03 is offline
i use tech deck stuff too. i cut off the tip of the skate tool and use it for a muffler. the tech deck mini tool works best.
Old 03-25-2004, 12:18 PM
N2O N2O is offline
Im With Stupid -->
Yeah i tried that but the tubes (see my tutorial--^)They are massive when youve finished with emm...Try it!
Tinyrc.com Rulez!
Best place to buy parts.... infinitemethod XMODS Parts and Hop-Ups 5 08-07-2004 08:08 PM
Mods Galore! PT Bruiser ZipZaps 5 10-19-2002 10:20 PM
parts and mods naseriously Bit Char-G / MicroSizers 1 10-17-2002 02:25 AM
