03-18-2004, 06:01 PM
motors wired in reverse some one plz look
hey guys.... one thing ive noticed with these cars are that the motors are wired in backwards....so if you buy an after market motor such as the hpi micro motor you would have to put the positive led to the negative on the motor...no running the motor in reverse is actually slower than if you wired the motor in positive to positive, get my drift? but if you would do that the xmod will run in reverse instead of going foward >.< it sucks cause i have a plasma dash motor and having it wired in backwards is slower than when i wire it correctly...positive to positive.... ok the point is...do you think wiring the motor clock-wise would fix the problem? plz help
03-18-2004, 06:05 PM
5Zigen
just switch the two wires or reverse the magnets.
Try And Sleep Now.
DRIFT my ANTI-rice
03-18-2004, 08:07 PM
or you can try flipping the motor upside down...
Xmods Civic:
Custom 36t 28gauge ball bearing neo mag motor, Soft treaded tires, 5 spoke rims, AWD, Hard springs in the back soft in the front, lowered BC's way, 6 cell with I-C3s, and one awsome drifter/driver/racer.
03-19-2004, 10:27 AM
I'm not a pyro, really.
reverse the magnets. just pull the endbell off and the little spring that holds them in and switch them. them put it all back together.
NEVER UNDERESTIMATE THE POWER
03-19-2004, 02:06 PM
but
so switching the position of the magnets will fix this problem...?
what about those 180 motors that cant be opened example ff-180ph?
03-19-2004, 03:37 PM
Just switch the wires...
Xmods Civic:
03-19-2004, 06:01 PM
okay, first of all...switching wires isnt the same as if you wired positive to negative cause the motor runs slower in reverse...so you posting swith the wires is a waiste of my time...did you read the first post i did up at the top?
03-19-2004, 07:48 PM
can you post a pic of the bell that cant be removed?
