Old 03-16-2004, 02:20 PM
geofroley's Avatar
geofroley geofroley is offline
R34 Skyline is God
Send a message via AIM to geofroley
Polycarbonate/Lexan paints
Can I use ploycarbonate or Lexan paints without primer?
My Bit: Phast motor (Orange)
Soon to come: (Undecided) Custom Rims
Old 03-16-2004, 02:30 PM
neurokinetik's Avatar
Mad Scientist
Yes, since they are designed to be used on the inside of a lexan body, it wouldn't make much sense to use primer, would it? Unless of course your intent is to have a shiny primer colored car...
Old 03-16-2004, 02:43 PM
geofroley's Avatar
R34 Skyline is God
Alright thanks. By the way, Can I use paint thinner to remove the paint without damaging the body?
Old 03-17-2004, 09:06 AM
Laszlo Laszlo is offline
yea just dont rub 2 hard cuz the thinner can start 2 eat away at the plastic
Old 03-17-2004, 02:11 PM
duwain
brake cleaner will take off paint. you just have to soak it for like 10-20 minutes from my experience. it took the spray paint off my rims.
Old 03-17-2004, 08:04 PM
Sky_Liner's Avatar
Sky_Liner Sky_Liner is offline
Send a message via AIM to Sky_Liner
Just buy some "oops" at walmart for like $2 it works well, just soak whatever in the OOPS! lol
*EDIT Oops will take off all the paint if you soak it, so just rub it in or put it on high grit sand paper.
Peace,
Fool's Gold........BC Finally Paints A Supra! Bad Company XMODS 41 02-24-2004 04:45 PM
Color shifting paints hostyle XMODS Mods and Projects 1 01-21-2004 12:58 PM
List of Recommended Paints ZipRC XMODS 1 11-01-2003 01:10 PM
what kind of paints should i use to paint my bit body? Presto Bit Char-G / MicroSizers 18 12-07-2002 10:23 AM
who paints on the inside, and who paints on the outside limelight Bit Char-G / MicroSizers 12 10-24-2002 11:19 AM
