Old 10-11-2002, 08:53 PM
joeNuggetz joeNuggetz is offline
Stupid Led Troubles
Since I'm having the worst luck with bad switches, does anyone know if there is a place on the bit pcb I can solder a led to. I want it to light up only when I hit the gas, like a Z-car. Or do I need a special board with other components on it?
Old 10-12-2002, 12:47 PM
Cal_Dereta Cal_Dereta is offline
Check out http://www.age.jp/%7Eex2/bit.html . The site is in japanese so you'll have to use a translator like http://babelfish.altavista.com/ . Basically, if you're gonna connect directly to the PCB, you'll have to use resistors. Otherwise, your motor will stutter. I used a TAMIYA MINI 4WD LED LIGHTING SET. They have resistors shrink-tubed onto the LEDs. I hope that helps.
LED switch Turboas ZipZaps 10 05-18-2003 12:50 PM
Unusual LED behavior InGaN Miscellaneous Discussion 0 01-30-2003 07:31 PM
Best Lightest LED MOD! scottyboyfun Bit Char-G / MicroSizers 9 01-07-2003 01:40 PM
Bad LED bulb? The Dude Bit Char-G Mods and Projects 7 11-15-2002 01:47 PM
